Author: Subject: Type 9 gearbox to 1.8 zetec, fitting clutch
RMarine
posted on 19/8/09 at 08:56 PM Reply With Quote
Hi, i have just assembled my Type 9 gearbox to my 1.8 zetec slivertop (from 1993 escort, using the escort/zetec flywheel, clutch and pressure plate with a spiggot bearing and its gone straight on, very easily. BUT.............should i be albe to move the clutch fork with my hand easily ?????
posted on 19/8/09 at 08:59 PM Reply With Quote
No, unless your arm is as strong as your left leg with the pedal ratio.
The arm should just pull up to the release bearing. Is it very loose? Got the correct release bearing?
RMarine
posted on 19/8/09 at 09:02 PM Reply With Quote
it from a sierra.... should the bearing just press against the leaves of the pressure plate ?
RMarine
posted on 19/8/09 at 09:06 PM Reply With Quote
a quick drawing of how i have done it
prawnabie
posted on 19/8/09 at 09:14 PM Reply With Quote
You should be able to move the bearing up to the clutch by hand yes, but to actuate the clutch by hand is impossble without leverage.
Shaun
posted on 19/8/09 at 09:15 PM Reply With Quote
Probably too short, you need a Capri release bearing which has a longer nose.
RMarine
posted on 19/8/09 at 09:35 PM Reply With Quote
when you bolt up the pressure plate to the flywheel should the leaves of the pressure plate be sticking out or flat?
paulf
posted on 19/8/09 at 10:01 PM Reply With Quote
Ive never been sure about this as my car has a mondeo clutch and a standard sierra release bearing and seems to work fine even though i have read many times that it needs the capri bearing.
Paul
goodall
posted on 19/8/09 at 10:36 PM Reply With Quote
come on he is a marine!
