Author: Subject: Replica Locost7 from Russia
Vetvrach
posted on 23/8/09 at 06:23 PM Reply With Quote
Hi, freinds
i have to present my Locost7. I worked on this car last 3 years. I took ing. motor & manual transmission from Lada
blakep82
posted on 23/8/09 at 06:35 PM Reply With Quote
good work
also like the matching outfit, and matching flower bed in the background
________________________
clairetoo
posted on 23/8/09 at 06:44 PM Reply With Quote
Its cuz I is blond , innit
Claire xx
Will weld for food......
omega0684
posted on 23/8/09 at 06:51 PM Reply With Quote
can we get some more shots of the lada engine
mookaloid
posted on 23/8/09 at 06:55 PM Reply With Quote
Welcome to the site
mackei23b
posted on 23/8/09 at 06:58 PM Reply With Quote
Well done, looking good.
Ian
lotusmadandy
posted on 23/8/09 at 07:19 PM Reply With Quote
Welcome and well done.As above
can we have some more pics please
where do you live in russia?
I have family there.
RichardK
posted on 23/8/09 at 07:29 PM Reply With Quote
Thats different, nice to see some creative building.
Welcome to the site by the way.
Regards
Rich
Gallery updated 11/01/2011
Vetvrach
posted on 23/8/09 at 07:32 PM Reply With Quote
I live in Moscow.
myke pocock
posted on 23/8/09 at 07:35 PM Reply With Quote
Is it solid rear axle? I am lead to believe that the Lada back axle is dimensionally identical to the Escort, that the Escort prop flange will fit the diff and that it has needle roller bearings and alloy drums. Therefore superior to the Ford axle. Anyone verify this?
Vetvrach
posted on 23/8/09 at 07:40 PM Reply With Quote
Rear axle from Lada as well
myke pocock
posted on 23/8/09 at 07:49 PM Reply With Quote
Ah, yes, just seen it on your site. Nice.
Vetvrach
posted on 23/8/09 at 07:54 PM Reply With Quote
Freinds,
i dont speak so good english. Actually there is 3 of us seating here and thinking how to answer everybody
There is Brake system, Fuel tank, steering colume, Wiring, clutch & shorting propeller shaft from Lada
richard thomas
posted on 23/8/09 at 07:59 PM Reply With Quote
Well done, it looks really good.
Is that the only one in Moscow?
Vetvrach
posted on 23/8/09 at 08:07 PM Reply With Quote
there is not so much projects like this in Russia. I am in first 5. I know all others.
dr-fastlane
posted on 23/8/09 at 09:19 PM Reply With Quote
welcome to locostbuilders!
The car looks really good. It’s good to see someone dare to take the adventure and building a car in Russia. Not the easiest country to do such project. Also did read your website, great work!
Must be a great feeling to drive it down the streets of Moscow (when it’s not to cold)
Greets Roy
[Edited on 23/8/09 by dr-fastlane]
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
blakep82
posted on 24/8/09 at 12:38 AM Reply With Quote
certainly looks just like the 'english axle' from the ford escort. a good find! i wonder if the diff etc are the same? worth looking into
iiyama
posted on 24/8/09 at 06:59 AM Reply With Quote
Privet!! Kak dela?
Ti Machina krasivaya!!
Still learning so probably dosent make any sense!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
CGILL
posted on 24/8/09 at 07:36 AM Reply With Quote
An escort head fits the lada housing if you make up a 3mm spacer.
Casting of side gears not quite as good as Ford item.
Nice and light though....
Early 3 series BMW discs (E28??) can be made of fit with a small spacer on the front uprights.
Gearboxes drop bearings easy, factory ones are soft, aftermarket ones do some justice.
daviep
posted on 24/8/09 at 08:24 AM Reply With Quote
Nice car, well done.
Regards
Davie
