Author: Subject: Forgot Ubuntu Administrator password
liam.mccaffrey
posted on 27/8/09 at 04:01 PM Reply With Quote
Any ideas how to change it??
Build Blog
Build Photo Album
BenTyreman
posted on 27/8/09 at 04:59 PM Reply With Quote
If you have sudo access on your user account (should have if you are using Ubuntu), then you can open a command terminal and run
code:
sudo passwd root
You will have to type your user password once, then it will ask you to type the new root password twice.
posted on 27/8/09 at 07:10 PM Reply With Quote
I wrote it on the table under the keyboard, didn't you think of that ?
liam.mccaffrey
posted on 27/8/09 at 07:33 PM Reply With Quote
sorted now by booting into command line and fireing some commands in
shockingly easy really
Build Blog
Build Photo Album
jlparsons
posted on 27/8/09 at 08:31 PM Reply With Quote
Bloody genius! I'll do that at work. I work in a bank.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
