flak monkey
posted on 9/9/09 at 11:55 AM |
Some engine weights, inc duratec and XE
A few people have been asking for a comparison of engine weights
These weights are for bare engines, block, head assembly complete with flywheel but no clutch!
Standard Duratec 85kg (less clutch/alt) with lightweight flywheel
Standard K-Series 89kg (less clutch/alt)
Standard Vauxhall XE 110kg
AFAIK the XE and Zetecs are similar in weight?
[Edited on 9/9/09 by flak monkey]
Sera
http://www.motosera.com
CraigJ
posted on 9/9/09 at 12:05 PM |
Is the duratec an all alloy block/head? Quite surprised by that weight.
flak monkey
posted on 9/9/09 at 12:08 PM |
Yep certainly is.
With std dual mass flywheel the weight is 92 kg
Sera
hughpinder
posted on 9/9/09 at 12:11 PM |
I weighed my 2.0 zetec silvertop with all the standard mondeo fittings, complete with starter, my engine mounts (originals removed), alternator,
clutch/flywheel, MTX75 gearbox(which is quite a lump on its own), driveshafts, instruments and engine loom, all rubber hoses that fit to the engine
and the water header tank, engine and gearbox oil E.g. as I will use it in my midi. No inlet or exhaust manifold though, came in at 188 kg using a
pair of salter scales. The scales agree on my weight (87 kg) to within 1 kg of the reading I get on the 'proper' scales at my local
leisure centre.
I remember vaguely that the 2.0 Zetec E is 18KG heavier than a duratec 2.0, but can't remember where I got that info.
Regards
Hugh
alistairolsen
posted on 9/9/09 at 12:15 PM |
an XE is not by any means 110kg. Perhaps as a bare engine with no manifolds or ancillaries!!
I weighed the one I put in my corsa with both manifolds, loom, ecu, pot flywheel (3.2kg heavier than the lighter one) starter, alt, belts and pulleys
fitted and it was 155kg.
My Build Thread
cd.thomson
posted on 9/9/09 at 12:16 PM |
the XE is 120kg fully prepped as far as I'm aware, re: QED motorsport.
or theres always:
Craig
flak monkey
posted on 9/9/09 at 12:19 PM |
All those weights are BARE engines. No ancils or clutches. Just the block, head and flywheel.
Sera
alistairolsen
posted on 9/9/09 at 12:34 PM |
sorry, realised that after I posted, doh!
My Build Thread
blakep82
posted on 9/9/09 at 12:37 PM |
or theres always:
i bet thats nice and cheap
________________________
alistairolsen
posted on 9/9/09 at 12:40 PM |
about 3k new iirc and they only did a limited run of them.
Not a chance you'd catch me using one and risking the tens of thousands in a proper build on an alloy block of unproven strength.
My Build Thread
omega0684
posted on 9/9/09 at 12:55 PM |
you forgot to do the pinto!
theconrodkid
posted on 9/9/09 at 01:12 PM |
not a pair of scales made that could weigh that
who cares who wins
pass the pork pies
blakep82
posted on 9/9/09 at 02:18 PM |
well, the queen mary 2 is 148528 tonnes...
i wonder how they weigh ships?
alistairolsen
posted on 9/9/09 at 02:21 PM |
They don't, one knows the underwater volume from the drawings and the draught marks and then using the density of the water in which shes lying
one can calculate the mass by Archimedes principle
My Build Thread
cd.thomson
posted on 9/9/09 at 02:23 PM |
one's a clever bugger
Craig
alistairolsen
posted on 9/9/09 at 02:34 PM |
One's a Naval Architect
My Build Thread
cd.thomson
posted on 9/9/09 at 02:56 PM |
thats the thing about One, I hear they do every job going, and have a degree in every subject.
If One doesn't know something, theres always another One who does.
Very very useful
Craig
jimgiblett
posted on 9/9/09 at 03:38 PM |
But a pinto won't float
- Jim
CraigJ
posted on 9/9/09 at 03:40 PM |
- Jim
Thats why its known as a boat anchor.
Doofus
posted on 9/9/09 at 04:12 PM |
So what you are saying is we should throw all the Pintos in the drink and measure how much the tide comes in....
Then we know how light they are
blakep82
posted on 9/9/09 at 05:58 PM |
ah, i was hoping for some kind of dry dock weigh bridge
mangogrooveworkshop
posted on 9/9/09 at 07:24 PM |
Fantastic
I got a Zetec delivered to my house a few days ago and FOOK ME its heavy....against a bike engine.
What is the differential between the crossflow weight to Zetec weight.
MikeR
posted on 9/9/09 at 08:08 PM |
Somewhere between "Ow" and "Owww Owww fuulming heck ow"
(aka i managed to knock my zetec off my build trolley and 'catch' it with my leg)
posted on 9/9/09 at 09:18 PM |
Not very much, the zetec is something like 10-15kg heavier IIRC.
Had to help a friend move some stuff in his garage a while back and he has a zetec ready for his Mk2 Escort. The two of us lifted it and I was
surprised at how light it felt, though it didn't have a flywheel on it.
[Edited on 9/9/09 by MikeRJ]
graememk
posted on 9/9/09 at 10:38 PM |
Eureka moment from paul there... your not going to run into town naked are you ?
