Author: Subject: Bellhousing for Toyota 3S-GTE Engine
Guinness
posted on 10/9/09 at 07:05 AM Reply With Quote
Is the 3S-GTE engine the same basic block as a 4a-ge? i.e. will the Raw bellhousing bolt up between it and a type 9?
Or are there any other Toyota gearboxes that bolt up to it?
Mike
deezee
posted on 10/9/09 at 07:41 AM Reply With Quote
I think the W55 gearbox has been successfully used to convert the 4AGE and the 3SGE to RWD. I'm not sure about the 3SGTE though, I imagine it would have the same bolt pattern as the 3SGE.
Project7
posted on 10/9/09 at 07:56 AM Reply With Quote
Mike
The 3SGTE and 4AGE are not the same block - infact the '3S' and '4A' denote the block version.
http://en.wikipedia.org/wiki/Toyota_S_engine
There is a JDM Lexus IS200 which uses a version of the 3S engine, so if you can source a gearbox from one of those it should bolt up.
nz_climber
posted on 10/9/09 at 08:01 AM Reply With Quote
It is different from the 4age, but the same as the standard 3sge, can get custom bellhousing to a t50 gearbox, but more common is a w55, w57 or w58 gearboxes with the right bellhousing will bolt straight up. And will handle the power of a 3sgte (t50 won't last long with a turbo 2L)
check out the following to find out about which bellhousings work
http://forums.toyspeed.org.nz/viewtopic.php?t=73257&highlig ht=rwd+bellhousing
http://aarons7.wordpress.com
mad-butcher
posted on 10/9/09 at 08:19 AM Reply With Quote
Linky
tony
Guinness
posted on 10/9/09 at 08:50 AM Reply With Quote
Should really have thought about searching first, but I'm sleep deprived this morning!
Mike
posted on 10/9/09 at 08:57 AM Reply With Quote
Hmm, I've got this lying in the garage... W58 I believe
Was attached to a 21R engine.
[Edited on 10/9/09 by coozer] Rescued attachment XT BOX 1 small.JPG
Guinness
posted on 10/9/09 at 09:07 AM Reply With Quote
Cool. How much would you pay me to clear some space in your garage then?
Mike
