Stuart_B
posted on 10/9/09 at 07:05 PM |
duratec bits
hi all, has anybody got a 1.8 none dual mass flywheel for sale?
and a duratec to type 9 box bellhousing for sale, let me know?
thanks
stuart
big_wasa
posted on 10/9/09 at 07:56 PM |
Flack is using the older zetec flywheel.
You dont need the timing gear on the back so why not use the 1.8cvh fly'
It just needs the holes drilling out from 10.5mm to 11mm a common mod.
Ring gear and clutch will all line up with the T9 as that was what it was fitted to.
just my two bob
flak monkey
posted on 10/9/09 at 08:25 PM |
just my two bob
Ahh so thats what it is? Do the numbers tie up to the pic i put in the duratec thread??
The starter is mounted on the block on the duratec.
Sera
http://www.motosera.com
Danozeman
posted on 11/9/09 at 06:38 AM |
Iv got a tiger 1.8 lightened zetec flywheel for sale if its any use.
Dan
Micael
posted on 11/9/09 at 02:29 PM |
So one can use the 1.8 zetec flywheel on a duratec?
That is Good news, then i can lower the budget with 300£
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
flak monkey
posted on 11/9/09 at 02:35 PM |
I need to check this out.
Anyone work for ford and can check a part number for me?
Sera
Stuart_B
posted on 11/9/09 at 03:22 PM |
there is someone on your thread about the engine swap david, how works for ford.
stuart
