New Topic New Reply
Author: Subject: Ali side and flor panels
ZEN
posted on 17/9/09 at 01:49 PM Reply With Quote
As the aluminium in 18swg (1.2mm) insn't aviable in my local area I was wondering if I could go to 1mm aluminium for the side and back panels or go for the 1.5mm?
Also I want to use aluminium for the floor. Is 2mm tick enough?
[Edited on 17/9/09 by ZEN]
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
blakep82
posted on 17/9/09 at 01:58 PM Reply With Quote
i thought 16swg was about 1.6mm anyway?
________________________
Bluemoon
posted on 17/9/09 at 02:15 PM Reply With Quote
I have used 1.5mm for all expect floor (can't remeber what this is off hand). 1.5mm is a bit thick but I quite liked using it in the end.. Thinner will help keep the weight down.. Make sure you get the correct grade and get half hard if you go 1.5mm other wise it will be a pain to bend..
Dan
[Edited on 17/9/09 by Bluemoon]
Daddylonglegs
posted on 17/9/09 at 02:18 PM Reply With Quote
I intend to use the thin stuff I have (about 0.8-1.0mm thick). I am assuming it will be OK as the areas where it is not supported (i.e. between cross members) is quite small, and the Sikflex should help too.
JB
ZEN
posted on 17/9/09 at 02:23 PM Reply With Quote
You are right! I wrote it wrong it should be 18swg.
Now I have corrected the error in the original post.
Maradona
posted on 17/9/09 at 06:54 PM Reply With Quote
I use 1,5 mm
Diego,
The locost builder from Argentina
ashg
posted on 17/9/09 at 10:11 PM Reply With Quote
i used 1.5mm 5000 grade for everything on my car and it was pig to bend round the back pannel. i had a dead arm for about 2days after bashing it round the tubes. i also had some very pissed off neighbours.
looks good now though as the extra thickness allows you to file out and polish up any little imperfections.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
New Topic New Reply
