posted on 22/9/09 at 12:06 PM |
Ford Auto Bellhousing?
Anyone got a rwd autobox lying around? I would be interested to see if the bellhousing comes off, and if so, how deep it is compared to a manual
bellhousing..
Anyone got one, or know where the knowledge can be found?
blakep82
posted on 22/9/09 at 12:09 PM |
mm, who's that bloke on here with an auto box? MautoK i think? he should have your answers
________________________
morcus
posted on 22/9/09 at 12:57 PM |
As above, He used a seirra auto I think.
I wouldn't have thought you could use an Auto Bellhousing with a manual box.
MautoK
posted on 22/9/09 at 01:05 PM |
Hello!
Here's an A4LD and Type 9 side by side:
![](/galpreviews/P1040076.JPG) ![A4LD & T9 - 1](/gallery/P1040076.JPG) A4LD & T9 - 1
I'll have a closer look and maybe take a pic into the b/h later if I can find the camera...
John.
MautoK
posted on 22/9/09 at 01:25 PM |
Looking into the bell housing:
![](/galpreviews/P1040616.JPG) ![A4LD B-Hsg](/gallery/P1040616.JPG) A4LD B-Hsg
and there's a 3mm thick gasket thingy between the b/h and main case:
![](/galpreviews/P1040614.JPG) ![A4LD Gasket](/gallery/P1040614.JPG) A4LD Gasket
You'll want to know how deep the b/h is, won't you?
It's about 6 1/4" from the front face of b/h to the front of the gasket thingy. Type 9 cast iron b/h is about 7" total length.
Sounds to me like a possible way to a lightweight bellhousing for Type 9 with a bit of macining and a spacer?
HTH
John.
MautoK
posted on 22/9/09 at 01:31 PM |
Bear in mind that the starter motor lives on the other side on the auto - don't know if the auto starter is the same as manual or different.
![](/galpreviews/P1040079.JPG) ![A4LD & T9 - 2](/gallery/P1040079.JPG) A4LD & T9 - 2
John.
posted on 22/9/09 at 04:36 PM |
Thanks for that John.
I have a Toyota Supra box I want to use and the auto bellhousing looks better to modify.
The shorter length gives me room for an adapter plate![](/images//smilies/bigsmile.gif)
