Author: Subject: windscreen replacement
stretch
posted on 28/9/09 at 07:52 AM Reply With Quote
my windscreen cracked
the problem is its glued to the alu frame with silicone - what will be the easiest way of getting the glass out without stuffing up the alu frame?
thanks in advance
Guinness
posted on 28/9/09 at 07:55 AM Reply With Quote
You can get "silcone eater":-
http://www.cglass.co.uk/everbuild-everflex-silicone-eater-pr-17657.html
But as ever, test on a small area first! Wouldn't want it to melt the frame too!
Mike
posted on 28/9/09 at 09:57 AM Reply With Quote
Yup. B+Q and screwfix both sell silicon remover. Whether it will "wick" between the glass and the frame is questionable. Otherwise it's a razor blade between the glass and frame....
posted on 28/9/09 at 11:12 AM Reply With Quote
I'd recommend a single-sided razor blade (arts and crafts shops will have them). Far safer!
AR-CoolC
posted on 28/9/09 at 11:43 AM Reply With Quote
Cheesewire will go through silicone very easily.
Imagine what it would be like if there were no hypothetical situations.
