Author: Subject: R1 Speed Sensor
fege
posted on 29/9/09 at 04:36 PM Reply With Quote
R1 Speed Sensor
Does anyone know if the Speed sensor is needed by the ECU in order to get an -99 4XV running properly?
locoR1
posted on 29/9/09 at 05:43 PM Reply With Quote
No its not needed as far as i can remember it just for the speedo!
Dave..
Check out my CB500T Cafe Racer build diary
nitram38
posted on 30/9/09 at 04:43 AM Reply With Quote
Have you bridged out the hand clutch switch and the side stand switch?
These will prevent your engine from starting.
Also make sure the gears are in neutral otherwise the N switch will cause a non-start too.
fege
posted on 30/9/09 at 05:19 PM Reply With Quote
Thanks for your help! And yes, I've shorted the clutch and the side stand. I've not yet tried to start the engine but thought I'd ask about the speed sensor before I cut it out of the loom.
