gavin174
posted on 29/9/09 at 09:10 PM |
which mk2 rack
need your views please...
have a locost chassis with widetrack and unsure what mk2 escort rack to use...
so i now have 3...
car will be used mainly on the road with some sprint trackdays..
please help!!!
[Edited on 29/9/09 by gavin174]
t16turbotone
posted on 29/9/09 at 09:28 PM |
I have a wide mcsorley chassis, ime currently using standard escort item, personally i feel i need the 2.4 rack
adithorp
posted on 29/9/09 at 09:30 PM |
This is the general advise I got when asking the same thing.
Standard is too light, too many turns.
2.4 too twitchy on the road but perfect on track.
2.9 best balance for road and track.
adrian
http://jpsc.org.uk/forum/
StevieB
posted on 29/9/09 at 09:45 PM |
I've just gone for a 2.8 for my sierra rack.
I could almost get away woth a standard rack but there's just a tiny amount too much lock for some of the tighter turns on trackdays - 2.8
should solve that but still allow enough precision to place the car properly on track without suffering any twitchiness.
Having said that, my mate uses the quikest rack Caterham do on his se7en and it's pretty perfect (1.8 turn IIRC).
procomp
posted on 30/9/09 at 07:25 AM |
Hi
with the Escort racks you will find that a STD travel and ratio is virtually useless.
The other options are a very rare Quaife 1.9 or a more common 2.2. Other rack manufacturers do 2.4 ratio as a quick rack. These are generally a 30%
ratio increase. There are some 2.9 lock to lock racks around but these are STD ratio with lock stops fitted so no benefit over a STD rack just less
travel.
The worst rack of the lot is the genuine Westfield item thats made by QH. That has reduced lock by not having the rack bar machined as far to give
less travel rather than lock stops fitted. It is sold as a quick rack but is actualy only an 18% increase in ratio.
In general a 2.4 is a good option for road and track use. A 2.2 or 1.9 are better suited to just track use.
Cheers Matt
gavin174
posted on 30/9/09 at 09:22 AM |
thanks for your replies..
as always you never get a 100 percent answer.. joins of individuals oppion i suppose..
maybe i should keep all 3 till its on the road and see from there
cheers
adithorp
posted on 30/9/09 at 12:16 PM |
quote: Originally posted by procomp
Hi
travel.
Cheers Matt
My 2.9 is deffinatly a lower ratio than standard and had no lock stops fitted. I know because I had a standard (3.5?) rack to compare it with that I
had decided not to use.
adrian
procomp
posted on 30/9/09 at 12:58 PM |
Hi
They do not necessarily have lock stops added as an extra fitment on the ends. They don't machine the rack bar the same distance / length as per
the Westfield STD item.
Cheers Matt
adithorp
posted on 1/10/09 at 02:16 PM |
...but when I compared my 2.9 with the standard one, it travelled the same distance but with less than3 turns compared to over 3.5 turns.
I don't doubt that there are some like you say, or even them all possibly being like that now, but the one I have isn't.
adrian
