Author: Subject: Tin Top engine rattle - further diagnostics
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 2/10/09 at 05:07 PM Reply With Quote
Hi all,
Further to my thread a few days ago about mt duratec engine rattle -
http://www.locostbuilders.co.uk/viewthread.php?tid=122558
I had a bit of a play and it seems that activating the air con or switching on significant electrical devices (heated screen etc) seems to bring on the rattle. Still only at idle though. Turn the a/c or screen off, and blip the throttle and let it return to idle and it goes away.
Does this lend weight to the idea of it being belt tensioner/water pump bearing? Or does it suggest something else?
Chris
DRC INDY 7
posted on 2/10/09 at 05:13 PM Reply With Quote
it will be the aux belt tensioner common fault fit a new aux belt as well
Puddle Dodgers Club
iank
posted on 2/10/09 at 05:16 PM Reply With Quote
Assuming both air con compressor pulley and alternator run off the same belt then it's something on that same belt that doesn't like the extra load caused by them absorbing power.
I'd use the 'stick' method or a stethoscope to identify which component it is.
Anonymous
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 2/10/09 at 05:29 PM Reply With Quote
Air con compressor, alternator, power steering pump and water pump are all on the same pulley. It is one mutha of a belt!
Chris
posted on 2/10/09 at 07:28 PM Reply With Quote
Chris
That's just a little belt.
novacaine
posted on 2/10/09 at 09:26 PM Reply With Quote
im going to bet its the aux pulley,
if its anything like fiat, happened on my punto, any electrical demand would bring on a loud clicking noise
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
Ninehigh
posted on 2/10/09 at 10:09 PM Reply With Quote
Had this on an Astra, it also happened when the revs dipped below idle speed, like when you're pulling away.. If that's the case you're probably just hitting a frequency...
Danozeman
posted on 3/10/09 at 09:29 AM Reply With Quote
Sounds like the water pump or a tensioner or idler to me.
That is a small belt. The ones on a duratorq transit/ convoy is litterally 9 ft long when cut..
Dan
