Author: Subject: Heated screen wiring
Humbug
posted on 3/10/09 at 05:38 PM Reply With Quote
OK, just bought a heated screen and put it on the car. I am wondering whether to connect the heater bit, but not sure what actually is needed. I have a spare switch on the dash which is currently connected to the engine fan *just in case* but I've never needed to use it. Do I need a relay for a heated screen and, if so, how would I wire the thing into the loom?
Any help gratefully received.
Simon
posted on 3/10/09 at 05:45 PM Reply With Quote
First thing it to probably connect it up across 12v and see what current it pulls with a multimeter. That'll fundamentally specify whether you can use a loom connection or a seperate relayed supply. If you haven't got a multimeter try connecting it via various ampage fuses (ie 1A, 3A, 5A). That'll tell you approx what ampage is being pulled by which ampages blow!!)...
Ben_Copeland
posted on 3/10/09 at 06:05 PM Reply With Quote
Another point to consider is a timer circuit.... so it doesnt stay on for too long.
My mondeo has timer circuits on both screens.
I'd recon you'll need 25amp circuit which means a relay !
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 3/10/09 at 06:21 PM Reply With Quote
Tintop HRW are always wired through a relay
Humbug
posted on 3/10/09 at 06:31 PM Reply With Quote
OK... so it looks like a relay is needed. How to I actually wire it in (in simple terms): wire from a fuse to the relay to the screen? wire from the other side of the relay to the switch? + earths?
madrallysport
posted on 3/10/09 at 06:42 PM Reply With Quote
Basic relay wiring diagram
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Mark Allanson
posted on 3/10/09 at 06:48 PM Reply With Quote
When I stripped my sierra ghia donor, the wires to the heated front screen were the thickest I have ever seen on an automotive circuit that did not involve a starter motor!
BIG relay required
Humbug
posted on 3/10/09 at 07:50 PM Reply With Quote
Thanks peeps
Humbug
posted on 9/10/09 at 09:43 AM Reply With Quote
Just called Caterham to say I had got a heated screen s/h from "another owner" and what rating relay and fuse do I need to fit?
Parts Dept said "dunno" and put me through to Engineering, and the answer is... No relay (!) and just a 10A fuse.
I have to say that the wires coming from the sides of the screen don't look particularly thick, so maybe (hopefully) that is correct.
Has anyone else got a Caterham heated screen and can confirm/rebut this?
Ben_Copeland
posted on 9/10/09 at 10:06 AM Reply With Quote
Guess they just use a beefyish switch instead.
Ben
Marcus
posted on 9/10/09 at 07:22 PM Reply With Quote
Yup, I'm running a Caterham heated screen, and no I don't use a relay. It hasn't blown a 6 amp fuse yet, so I wouldn't worry
Marcus
Because kits are for girls!!
Humbug
posted on 10/10/09 at 09:33 PM Reply With Quote
Good news!
Simon
