rossymond
posted on 3/10/09 at 05:58 PM |
98-99 ZX9 Fuel Pressure
Hi all, anyone know what the stock fuel pressure is on the 98-9 ZX9 pump?
Its a neat size to replace my dead fireblade pump, and im hoping it goes to the 1.5psi that the blade pump goes too.
many thanks.
posted on 3/10/09 at 10:47 PM |
It will most likely be the same Mitsubishi pump as your Fireblade. You can get spares for fuel pump from Wemoto.
rossymond
posted on 3/10/09 at 11:16 PM |
Ah excellent ill have a search. thanks
Danozeman
posted on 4/10/09 at 08:55 AM |
aslong as theyr both carb pumps they will be near enough the same.
Dan
mistergrumpy
posted on 4/10/09 at 11:47 AM |
Mr Haynes says that the fuel cut off pressure for the pump is 1.6 to 2.3 psi.
rossymond
posted on 4/10/09 at 03:35 PM |
Right i see, thanks guys, ill buy the pump as its only cheap on ebay, its from a carbed engine so worse comes to worse ive only lost a few quid.
