Author: Subject: IVA and side pannels
dunk3
posted on 9/10/09 at 07:34 AM Reply With Quote
Hi all, has anyone taken a MK INDY for the IVA test with side pannels open at the front suspension area, and had any problems, as i was told they now have to be fully enclosed. Rescued attachment braided brake pipe fitted 1.jpg
rallyingden
posted on 9/10/09 at 07:38 AM Reply With Quote
I hope not coz thats how mine are but I have put some edge trim on to keep the tester happy.
RD
Daddylonglegs
posted on 9/10/09 at 07:44 AM Reply With Quote
Is that not going to let mucho cr*p into the engine bay though?
l0rd
posted on 9/10/09 at 08:28 AM Reply With Quote
Wouldn't it though let more air as well?
myeates
posted on 9/10/09 at 08:32 AM Reply With Quote
thats how mine are it passed sva with edge trim on the panel dont know if any different now. it doesnt let much dirt in and its been used in some fairly horid weather
rallyingden
posted on 9/10/09 at 08:57 AM Reply With Quote
I've seen plenty like this but as for passing IVA not sure but dont see what the problem would be providing no shap edges.
RD
Daddylonglegs
posted on 9/10/09 at 09:45 AM Reply With Quote
Good point, well presented
kendo
posted on 9/10/09 at 09:47 AM Reply With Quote
I think you might have a problem.
In IVA they limit how much lurid green paint you are allowed as you may inadvertently dazzle a pedestrian as you run them over.
Seriously though so long as edges and protrusions are protected it shouln't be an issue.
dunk3
posted on 9/10/09 at 09:54 AM Reply With Quote
just being reading the IVA manual chapter 16 Exterior Projections i hope ive read it wrong.
l0rd
posted on 9/10/09 at 10:09 AM Reply With Quote
Is it the weird camera angle or is that braided hose toooo short?
blakep82
posted on 9/10/09 at 10:32 AM Reply With Quote
think it should be fine.
ariel atom for example
________________________
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 9/10/09 at 11:12 AM Reply With Quote
Thats what i thought, though it might be just the camera angle but if its not there is no way you'll get full left lock
mad4x4
posted on 9/10/09 at 11:56 AM Reply With Quote
Looks like the panel is fouling the trailing edge of the lower arm aswell..
Scot's do it better in Kilts.
dunk3
posted on 9/10/09 at 04:15 PM Reply With Quote
Hi all, the side pannel is not fitted its just a trial fit to use as a example to explain the question better, sorry for the confusion,
