Author: Subject: Where to get sump gaskets...
franky
posted on 11/10/09 at 09:19 PM Reply With Quote
Thought I'd get away with using my original sump gasket.... hence why i'm now looking for a zx12r sump gasket
Can't seem to find anywhere to buy one...... Any ideas?
posted on 11/10/09 at 09:21 PM Reply With Quote
I've used bike bandit in the states in the past. Cheap (especially considering the exchange rate)....
mark chandler
posted on 11/10/09 at 09:28 PM Reply With Quote
I just used a very fine smear of sump sealant from halfords, the joy of bike engines is the quality of the castings so only a tiny amount required.
franky
posted on 11/10/09 at 09:29 PM Reply With Quote
Good price bar the fact post is $50
hobbsy
posted on 11/10/09 at 09:30 PM Reply With Quote
If using some kind of sealant using it very sparingly as Mark said as excess sealant clogging the oil pickup filter is a common cause of engine failure apparently.
Browny
Junior Builder
Posts 32
Registered 6/6/07
Member Is Offline
Photo Archive Go!
Building: Space framed Fiat Seicento with zzr1400 engine.
posted on 11/10/09 at 09:31 PM Reply With Quote
Whats wrong with your local Kawasaki main dealer? I've just bought a clutch cover gasket for my zzr1400 engine, £15.00 and they had it in stock the following day.
eddbaz
posted on 11/10/09 at 09:39 PM Reply With Quote
As above,local kawasaki dealers can supply required gaskets.
franky
posted on 11/10/09 at 09:42 PM Reply With Quote
I'll give them a call tomorrow.... if its overly priced i'll use sealant.
mangogrooveworkshop
posted on 11/10/09 at 09:54 PM Reply With Quote
Use the correct gasket unless you can afford a new engine. Saving a few pounds in this case is a bad idea.
MautoK
posted on 11/10/09 at 11:32 PM Reply With Quote
I've had gasket paper and NBC from these folks to make my own autobox sump gasket and others. If the old one can be used as a pattern it's easy.
John.
MakeEverything
posted on 12/10/09 at 07:00 AM Reply With Quote
You can use Gasket compoind, but make sure you dont put too much on so it squishes out on the inside. Even a little bit can clog up your filters and oilways and its a nighmare to get out.
Personally, id try and find the gasket as you are. Longer waiting time, but you know its done properly.
Kindest Regards,
Richard.
franky
posted on 12/10/09 at 08:52 AM Reply With Quote
£13.64 from Kawasaki
P ?
posted on 12/10/09 at 11:48 AM Reply With Quote
i got a busa gasket from main dealers at 12.95 so worth giving them a call
MautoK
posted on 12/10/09 at 08:07 PM Reply With Quote
Gasket paper is typically £1.00 per 255x480mm sheet.
