blakep82
posted on 12/10/09 at 04:12 PM |
daytime running lights?
what are they?
i seen this on CBS:
IVA rules state that Daytime Running Lights must come on with the ignition and turn of when the headlamps are turned on. This module controls this
function automatically for LED lights ONLY. Input leads 1 mtr long. Output leads (for two lamps) 1.7mtrs long with male and female bullet terminals.
here
first i've heard... can't find anything in the manual either
am i missing something?!
[Edited on 12/10/09 by blakep82]
________________________
luke
posted on 12/10/09 at 04:23 PM |
Daytime running lights are what the audis are fitting now. strip of LEDs along the underneath of the headlights
i heard on grapevine they will become compulsary on all manufactured cars, dont know when, or wether it affects kit cars too.
EDIT just looked in IVA manual, section 22, listed as optional.
[Edited on 12/10/09 by luke]
Humbug
posted on 12/10/09 at 04:28 PM |
I think the Audis look like they have disco lights on them, especially the ones where the strip of lights is curved
Humbug
posted on 12/10/09 at 04:31 PM |
blakep82
posted on 12/10/09 at 04:40 PM |
audi's look cool
so are they basically sidelights then?
luke
posted on 12/10/09 at 04:58 PM |
basically yer,
they run on the same principle that volvos use, any aid to make it slightly more obvious that there is a big chunk of metal there.
Canada EH!
posted on 12/10/09 at 05:59 PM |
Been run in Canada for years, ususally main beam headlight with a resistor to make it less bright, some are triggered by the light switch, others by
the speedo sensor.
Of late many new North American cars are using the turn indicator bulbs on both sides at the front.
Law requires two lights at the front of the vehicle one on each side, no rear lights.
Some Japanese manufacturers just have all the normal road lights come on with the run side of the ignition.
matt_claydon
posted on 12/10/09 at 06:00 PM |
They are not like side lights, they are far brighter. That's why they have to go off when the headlamps come on, otherwise they would dazzle
other people at night.
They will be becoming compulsory for Type-Approved cars in the future.
mad4x4
posted on 12/10/09 at 06:01 PM |
Ebay you can get strips of LED's for about 8 quid - Very bright Could be mounted in the nose cone sunk into the front edge of a cycle wing to
give that cool AUDI LOOK
EABY AUCTION 260450553676
Scot's do it better in Kilts.
Ninehigh
posted on 13/10/09 at 08:50 PM |
Looks like they'll be doing this in preparation for the influx of electric vehicles...
blakep82
posted on 14/10/09 at 11:50 AM |
ah, right, i get it now, just looked up section 22, they are optional, but IF you have them then, IVA rules state that Daytime Running Lights must
come on with the ignition and turn... blah blah blah.
won't worry about that for now then
maybe by the time this car's done tho...
Ninehigh
posted on 14/10/09 at 07:16 PM |
So does this mean you can't have sidelights hardwired to the ignition so they're always on when driving?
Steve @ sVc
posted on 15/10/09 at 09:05 AM |
As far as I know ......... ............ day-time running lights will be compulsory on new vehiclesregistered at a ate I have not been told of yet, in
2010. IVA does not seem to have addressed this as yet. However, if they decide that it is needed the lights will have to be “E” marked as daytime
running lights. As previously stated these are far brighter than side lights, and because of this must be off when you turn your lights on, after
sun-set.
We have looked at 8 of these and have not found (yet) any that seem to be cost effective, are not huge AND are “E” marked for purpose.
Regards Steve @ sVc
iank
posted on 15/10/09 at 03:45 PM |
I believe you can.
If you have daylight running lights do they mean you don't require sidelights? (which would be a bit pointless if you did)
Anonymous
posted on 15/10/09 at 03:57 PM |
The thing to remember about 'sidelights' is that the IVA manual calls them 'position lamps', i.e. they tell other motorists
where you are when you're parked.
You probably wouldn't want to leave those driving lights on for a couple of hours without the engine running, plus they'll really pee off
passing motorists.
