rayroni
posted on 17/10/09 at 10:59 AM |
Pipe Flange
I am trying to fit a 32mm (internal) coolant hose to a steel pipe that has no flange, obviously this ain't a good idea as the hose will come off
under pressure - what is the best way of creating a flange on the pipe, bearing in mind that the pipe is a little difficult to access?
All suggestions appreciated!!
Cheers.
blakep82
posted on 17/10/09 at 11:11 AM |
if its steel, run a small bead of weld around it
________________________
posted on 17/10/09 at 11:27 AM |
Normally lack of a bead is not a problem especially if you are using rubber hose.
