<<  1    2  >>
New Topic New Reply
Author: Subject: Indy front suspension
Echidna
posted on 20/10/09 at 04:55 PM Reply With Quote
Any chance from anyone to take some pictures of the Indy front suspension? I am particularly interested to see the position of the wishbones and steering rack in relation to the front section of the chassis. Thanks in advance!
[Edited on 21/10/09 by Echidna]
kitCARBON is the new carbon composite parts company specialising in kitcar parts. We can make parts to order in carbon, carbon/kevlar, kevlar, texalium and more!
For any question, just U2U or email me at
theodragonas@gmail.com
posted on 20/10/09 at 05:34 PM Reply With Quote
Gimme 5 minutes - I'll go get a picture.........
Phil
posted on 20/10/09 at 05:42 PM Reply With Quote
This any good?
Suspension 1
Suspension 1
Phil
Flamez
posted on 20/10/09 at 05:44 PM Reply With Quote
From a Mac1
hth
my build mac1motorsports
PAUL FISHER
posted on 20/10/09 at 05:59 PM Reply With Quote
And the front of my old Indy R (inboard suspension) .
Echidna
posted on 20/10/09 at 06:03 PM Reply With Quote
Thanks a lot guys. I am going to build an antiroll bar kit for a friend's MK, that's why i asked for pics. My friend's car is 200kms away though..
Echidna
posted on 20/10/09 at 07:04 PM Reply With Quote
Mainly setup fine tuning. The antiroll bars will be adjustable in some positions, so we will be able to alter the roll resistance distribution between front and rear, thus to play with weight transfers to the outer wheels. This will help to play with understeer/oversteer thingies.
procomp
posted on 21/10/09 at 08:04 AM Reply With Quote
Hi
Before you even think about playing with weight transfer. You will be wanting to get a set of dampers specially valved to actually work in that aplication.
Cheers Matt
Echidna
posted on 21/10/09 at 05:27 PM Reply With Quote
Matt, thanks for your suggestions. Actually we are going to test the car after we fit the antiroll bars, and certainly we will also change the shocks or revalve them according to requirements. Maybe we will need your services as i see that you have a shock dyno which will prove valuable for us.
My friend's Indy has normal Protech ccoilovers. We will certainly need some professional to test them and revalve them. Can you revalve our Protech shocks? Thanks!
Echidna
posted on 21/10/09 at 08:12 PM Reply With Quote
Could anyone supply the following data:
1) Front weight / rear weight for the average bike engined MK Indy
2) Weight of unsprung components front/rear
Thsi would be the sum of rims, tires, hubs, uprights, brake components, wishbones. Let's take an average weight for the wheels (rims, tires)
3) Height of suspension roll center front / rear
4) Spung mass CoG front / rear
5) Wheel movement / Spring movement ratio
I know that some of these are a bit hard to know but i will really appreciate if you could give me some of the above data. Thanks!
Echidna
posted on 22/10/09 at 08:04 PM Reply With Quote
Anyone?
Echidna
posted on 27/10/09 at 06:55 PM Reply With Quote
Anyone could measure the distance from damper to damper at the lower bolts points?
Echidna
posted on 27/10/09 at 07:07 PM Reply With Quote
Another question:
Could anyone (Hellfire maybe?) measure the distance (clearance) between the lower bolt (front side) of the front damper and the steering link in front of it? Rescued attachment IMG_3575.JPG
posted on 27/10/09 at 08:37 PM Reply With Quote
Distance between the bolt and the steering arm is 70mm +/- 2mm (The steering extensions don't run parallel with the head of the bolt) This measurement reduces to 50mm on full lock (Just in case you need to know)
Phil
Echidna
posted on 28/10/09 at 06:21 AM Reply With Quote
Thanks again Phil, you are so helpful!
Could you also measure the distance from damper to damper (opposite side) at the lower bolt points?
And a last question, what is the distance from the lower damper bolt to the top wishbone, as shown by the green arrow? Thanks a million times!
[Edited on 28/10/09 by Echidna]
posted on 28/10/09 at 05:38 PM Reply With Quote
The measurement between lower damper mounts is 1040mm c/c. Clearance between steering arm and upper wishbone is approx 125mm.
Phil
Echidna
posted on 28/10/09 at 06:00 PM Reply With Quote
Thank you very much Phil!
posted on 28/10/09 at 06:17 PM Reply With Quote
No problem. Let me know if there's owt else you need apart from numbers 1 to 5 above. I can't just pop into the garage and measure those for you
Phil
Echidna
posted on 28/10/09 at 06:23 PM Reply With Quote
The last thing i would like is a picture with the nosecone off, so i can see where i can mount the antiroll bar. Probably the radiator is a problem there so i need a picture with the nose off.
mackei23b
posted on 29/10/09 at 03:14 PM Reply With Quote
Here is a pic of mine, shows the radiator mounting, but the radiator is not attached, it mounts on the front of the frame. Hopefully this should give you a good idea of the location and still show the chassis.
Ian
Echidna
posted on 3/11/09 at 08:59 PM Reply With Quote
Thanks!
Anyone can post a pic with the radiator fitted?
posted on 3/11/09 at 09:10 PM Reply With Quote
Does this picture help?
Phil
Fozzie
posted on 3/11/09 at 09:46 PM Reply With Quote
OK so which of you has gone and linked a picture/s to a 'ftp' site?
posted on 3/11/09 at 09:52 PM Reply With Quote
You're the Mod, you tell us.....
Phil
ETA - But seriously..... won't the clue be in the image properties?
[Edited on 3-11-09 by Hellfire]
Fozzie
posted on 3/11/09 at 09:56 PM Reply With Quote
Phil
Yeah funny...NOT...... Admin does NOT equate psychic
<<  1    2  >>
New Topic New Reply
