robocog
posted on 26/10/09 at 08:05 PM |
New brakes
OMG!
Just swapped my old Sierra master cylinder for a Fiat item (cheapo eBay job) , mounted a remote reservoir (Daihatsu HiJet)
Swapped the vented disks for Sierra solids
Changed the calipers from vented Sierra to solid KA, and treated it to new Mintex 1144's as the greenstuffs I was running were a different
shape/size
Just come in from bleeding the fronts
It would have been rude not to give em a prod...so rolled it forwards and gave it a prod...
Nearly broke my nose on the steering wheel, wasn't expecing it to bite quite like that, especially as I had just had a hose on the car to wash
the inevitable spillage I couldn't see in the dark
I'm going to have to put a post it note on the steering wheel for its first shakedown after the changes...or fit a thick spongy pad to the pedal
From it needing a healthy prod to get wheels to lock it now feels overbraked from the short tests I just did
Hoping they will soften a little with use
Especially now it starting to get cold and damp!
Master cylinder was 22, now 19 IIRC
Disk diameters are the same
Pad surface area is a little smaller than they were by the looks of it
Pedal pivot/ratio/length is the same.. as nothing got changed other than a de rust and lick of paint
Thought it would be of interest
Seemingly a world of difference for very little outlay
Sierra Solid Disks £5 each
KA calipers - free
hijet reservoir £5
pads £5 - no one else bid so it was 99p and £4 postage
Fiat master cylinder £15
...throwing the battery off the bulkhead and nearly taking my face out on the steering wheel....priceless
Regards
Rob
posted on 26/10/09 at 08:43 PM |
Any pics of the setup??
whitestu
posted on 26/10/09 at 09:29 PM |
I'm in the middle of installing a Fiat non-servo M/C as well, so this is reassuring!
Hopfully mine will improve as well. though I'm keeping the same calipers and disks.
Stu
robocog
posted on 26/10/09 at 09:41 PM |
No pics yet
Got Thursday off so should get a chance to photograpah the pre-winter mods and give it a shakedown
Only just discovered ACF50
Seems to be working well so far
Hopefully it wont get in such a rotten state so fast
Regards
Rob
robocog
posted on 26/10/09 at 10:44 PM |
The master cylinder I got was This
one
the blurb from the ad..
BENDIX 132233B
19.05mm
BRAKE MASTER CYLINDER
SUITABLE REPLACEMENT FOR
FIAT PART No 793010
SUITABLE FOR THE FOLLOWING FIAT VEHICLES
WITH BENDIX BRAKES
LEFT HAND DRIVE (UNLESS STATED)
FIAT VEHICLES
SEE DISCRIPTION & CHECK PHOTO & PART NUMBER
AGAINST YOUR MODEL
FIAT PANDA 1000 From Chassis No 6261412
JAN 1985 -- DEC 1992
FIAT PANDA 1000 i.e From Chassis No 6261412
OCT 1987 -- JAN 1993
FIAT PANDA 1100 From Chassis No 6261412
JAN 1993 -- JAN 1995
FIAT PANDA 750 From Chassis No 6223908
JAN 1986 -- JAN 1991
FIAT PANDA VAN 1000 From Chassis No 6261412
JAN 1986 -- FEB 1992
FIAT UNO 1.3 Super Diesel From Chassis No 0038873
LEFT & RIGHT HAND DRIVE VEHICLES
JUNE 1983 -- JAN 1985
FIAT UNO 45 0.9 From Chassis No 0723819
MAR 1983 -- JAN 1989
FIAT UNO 45 1.0 From Chassis No 0723819
JUNE 1986 -- JAN 1989
FIAT UNO 45 i.e 1.0 From Chassis No 0723819
APR 1984 -- JAN 1989
FIAT UNO 55 1.1 From Chassis No 1570529 / 0324161
JAN 1983 -- JAN 1989
Regards
Rob
rsmith95uk
posted on 26/10/09 at 11:06 PM |
is there any modification required for the caliper change?
Ray
robocog
posted on 26/10/09 at 11:17 PM |
Nope, no mods required
KA claipers just bolt straight up to the Sierra hub
I used a Sierra Solid disk, but there were a few other options that were as good as identical...
It just so happened I scored a new pair of Sierra solids at £5 a pop because the packaging was a bit chuffed and the guy was local enough for me to
collect in person
I did end up replacing my braided hoses (bought from Mr Russ Bost on here) as my old ones seemed just a little shorter with the new calipers ...but
the engine wasn't in and possibly wasn't completely necessary, but worth while as the new hoses are just lush compared to the old ones
(highly recomend his services!)
Will report back on how well the new setup really works on Thursday assuming the weather is not too bad and I get the rest of the stuff bolted up and
the wings glued back on :-)
My guess is that its the smaller bore of the master cylinder that has made the most dramatic difference to the setup
Regards
Rob
whitestu
posted on 27/10/09 at 09:21 AM |
That looks like a good buy - mine was £19 plus vat. It also appears to have 10x1.25 thread on the inlets so I need to change the unions on my brake
pipes which is a bit of a pain.
Stu
