Author: Subject: Sierra Clutch Pedal RATIO [cable type]
Cobra289
posted on 2/11/09 at 07:04 PM Reply With Quote
Perhaps someone can help me.
I am looking for the distance between the pivot point of the pedal and the foot pad.
If I am right the pivot is the center of the quadrant that has a radius of 45 mm
So if you let me know the distance, I can calculate the pedal Ratio.
I am talking here about the Sierra clutch pedal with a cable system.
Best regards,
Cobra289
miikae
posted on 2/11/09 at 07:16 PM Reply With Quote
Approx 275mm from the quadrant center pivot to the centre of the pedal, HTH
Mike
If it can be done it i will be done .
Cobra289
posted on 2/11/09 at 07:58 PM Reply With Quote
Mike
Many thanks!
I will use at my design.
Best regards,
Cobra289
SteveWalker
posted on 2/11/09 at 09:44 PM Reply With Quote
Don't forget that if you want to adjust it later, you can just buy a different diameter quadrant. You probably know that anyway though.
Cobra289
posted on 2/11/09 at 09:49 PM Reply With Quote
No I didn't know that, I thought that every pedal did use the 45 mm quadrant.
I will not use the quadrant [plastic] but will integrate a similar design in my pedal.
The question arise, is the 45 mm quadrant the standard one?
Regards,
Cobra289
