Author: Subject: Cleaning galvanised steel???
MK9R
posted on 11/11/09 at 11:21 AM Reply With Quote
My trailer is looking a bit dull, is there anything that will make the galvanising look bright again?? I was thinking something like cilit bang may do the trick?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
blakep82
posted on 11/11/09 at 11:25 AM Reply With Quote
some sort of rubbing compound might do it better i think?
________________________
MikeCapon
posted on 11/11/09 at 11:27 AM Reply With Quote
Your pal, as ever, is Google
Click me
ETA Correct stupid spelling mistake. Not bad in 8 words eh?
[Edited on 11/11/09 by MikeCapon]
MK9R
posted on 11/11/09 at 11:30 AM Reply With Quote
Click me
Been reading that. CLR seems to be similiar stuff to Cillet
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 11/11/09 at 11:34 AM Reply With Quote
arh, just read on Cillet bang website (my god i must be bored!) not suitable for zinc coated metal
Cheers Austen
RGB car number 9
www.trackace.co.uk
sprouts-car
posted on 11/11/09 at 11:44 AM Reply With Quote
Bang and the zinc is gone
posted on 11/11/09 at 12:00 PM Reply With Quote
coca-cola? vinegar?
Visit China. Meet the child that made your trainers.
MakeEverything
posted on 11/11/09 at 12:02 PM Reply With Quote
Polish a trailer???
You must be bored!
Kindest Regards,
Richard.
Bluemoon
posted on 11/11/09 at 12:17 PM Reply With Quote
I'd not bother, just wash.. The dullness is the Zinc oxidizing rather than the steel... If you want to make it bright again you will remove this top layer and probably increase the rate at which the zinc is lost..
I.e. reduce the life of the trailer..
Dan
MK9R
posted on 11/11/09 at 12:20 PM Reply With Quote
Dan
Was just trying to make it look nice for the new owner, i'll just hose it down
Cheers Austen
RGB car number 9
www.trackace.co.uk
Bluemoon
posted on 11/11/09 at 12:39 PM Reply With Quote
Just wash with some car shampoo then.. Should be fine. Just don't wash the grease of the mechanical bits..
Dan
dhutch
posted on 11/11/09 at 01:09 PM Reply With Quote
Yeah, as said, the dullness that zinc coating develop over time is the formation of zinc oxide. Ie, your looking at and oxide layer not bright zinc.
However unlike ferrus oxide (red rust) the zinc oxide forms a coheasive layer with then protects the under lying zinc, so although you can removed it and get back to bright zinc you are actaully damaging the coating in the process.
If you do want to do anything to trailer coatings to improve then, the thing to do it keep the clean in the early life (first 6 months or year) so the oxide forms in a nice even layer. Makes them last longer and makes the oxide look a bit nicer. As detailed in most trailer care booklets i guess, certainly mentioned on the ifor williams info guff.
Daniel
