Author: Subject: hayabusa clocks/speedo wiring diagram.
franky
posted on 16/11/09 at 06:48 PM Reply With Quote
I'm looking for a wiring diagram for a set of hayabusa clocks... I've looked in a service manual but it doesn't actually say.
What I need are the pins on the clocks that provide power. can anyone help?
speedyxjs
posted on 16/11/09 at 08:19 PM Reply With Quote
When i needed similar info for my car, i ended up emailing the manufacturer (lucas in this case). They were able to send me the right info.
cosmick
posted on 16/11/09 at 08:40 PM Reply With Quote
Hayabusa Clocks wiring Info
I can tell you the following information.
Grey - illumination/ side lights.
Black/White - Earth x 2 of these.
Black/Red - Speedo Pulse from sender.
Pink - Speedo voltage to sender.
Yellow/Blue - Tachometer.
Black/Green - FI Light and code.
Red/Blue - Permanent live for clock memory.
Light Green - Right Hand indicator.
Orange/Green Switched live from ignition key.
Black - Left Hand indicator.
Green/Yellow - Oil pressure switch.
Yellow - Main beam indicator.
Blue/Black - Neutral light.
Yellow/Black - Fuel gauge.
Hope this helps.
Cosmick.
franky
posted on 17/11/09 at 02:15 PM Reply With Quote
cheers!
cosmick
posted on 17/11/09 at 02:43 PM Reply With Quote
Is this what you were after?
