Author: Subject: sharpening Lathe cutting tools
thepest
posted on 28/11/09 at 11:09 AM Reply With Quote
Anyone got some good reference for this? I never seem to be able to get the bits as good & sharp as new. Anyone got advice or help?
mangogrooveworkshop
posted on 28/11/09 at 11:59 AM Reply With Quote
You have to have a jig on your stone that has the two angles preset to get a good result.
We used to do this but we all have moved over to replaceble inserts on tool holders for myfords
On the web there is a page with these critical angles but the bookmark is expired. One mr jenkins can maybe shed light on this page.
[Edited on 28-11-09 by mangogrooveworkshop]
trextr7monkey
posted on 28/11/09 at 12:12 PM Reply With Quote
Clueless on this now myself as we are moving over to replaceable tips but one of the technicians - 60 odd years old trained as a turner with Royal Ordnance making 50' gun barrells etc so he makes his own tools from first principles, very skillful.Mike
robocog
posted on 28/11/09 at 12:30 PM Reply With Quote
Ian Bradley talks LatheTools should help...as well as a host of other invaluable stuff
File is zipped and is 30 megs of goodness
Clicky here
Enjoy :-)
Regards
Rob
Mal
posted on 28/11/09 at 01:01 PM Reply With Quote
If you want to see replaceable tip tooling suitable for most home use size lathes take a look atthis website
chronos.ltd.uk
clanger
posted on 28/11/09 at 02:10 PM Reply With Quote
A good tip for you. When you've got the angles set right (try adjusting the grinder tool rest if your struggling) look for the tell tale signs of the grinding sparks bouncing off the top of the leading tool edge. This will give you a good idea as to when the tool is nearing its keenest edge.
Thry to keep the angle of attck consistent, it comes with practice, and don't overheat the tool.
Also when you've sharpened it, just knock off the pointy bit with a light going over on the fine wheel or use a sharpening stone. It should improve the finish. Best of luck !
posted on 28/11/09 at 03:41 PM Reply With Quote
Your wish is my command...
LINKY
Look down the contents page for the bit about lathe tools and sharpening.
mangogrooveworkshop
posted on 28/11/09 at 05:53 PM Reply With Quote
LINKY
Never let me down thanks
fazerruss
posted on 28/11/09 at 08:29 PM Reply With Quote
You can sharpen without specialist tooling but if you are using tungsten carbide tips you will need a green grit wheel on your grinder. Ordinary stone wheels are no good
"if assholes could fly this place would be an airport"
thepest
posted on 30/11/09 at 07:56 AM Reply With Quote
thanks guys all very helpful
