Micael
posted on 29/11/09 at 07:07 PM |
Duratec lifters again
I plan to remove the valves on my duratec.
Do I need to adjust the valve clearence after that?
I don't plan to do anything with the valves/seats. I just want to examine them.
It seems to be an expensive job to sort out all the buckets, if i have to adjust them.
Does anyone know how much is safe to skim a duratec head?
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
flak monkey
posted on 29/11/09 at 08:04 PM |
As long as you refit the valves and buckets back in their original positions they will be fine.
Not sure on the max you can skim the head.
Sera
http://www.motosera.com
snapper
posted on 29/11/09 at 08:26 PM |
Might be worth looking at a thinner (Cometic) gasket unless you want some serious compression.
AND i thought Duratecs needed different pistons to increase compression, could be wrong!
I eat to survive
I drink to forget
flak monkey
posted on 29/11/09 at 08:36 PM |
Skimming the head will increase CR, but I dont know how much is safe, probably not much and for little gain. The std CR is already 10.8:1 and most
high compression pistons will take it to 12.5:1.
Sera
Micael
posted on 30/11/09 at 06:46 PM |
Thanks for the replys.
I plan to skim the head only to make certain that the head is dead straight.
I hade enough of warped Zetec heads and blown head gaskets. So i don't want to start out with a blown Duratec head gasket.
Micael Moose Åman
2009
