New Topic New Reply
Author: Subject: back bone chassis
smart51
posted on 29/11/09 at 07:07 PM Reply With Quote
back bone chassis
I know back bone chassies can be very stiff in torsion but isn't there a risk that they'll bend so that the wheels on one side are closer together than the other?
This particular car has a metal frame in the body tub for crash / rollover / side impact protection. Rescued attachment F16 chassis front.jpg
speedyxjs
posted on 29/11/09 at 07:13 PM Reply With Quote
Nice pic but i wouldnt be too happy having a crash in that, even if the body is 'safe'
iank
posted on 29/11/09 at 07:29 PM Reply With Quote
I wouldn't even call that one a backbone. More two subframes connected by a small tube. A real backbone is much larger in cross section and often triangulated.
Like this:
or:
So in answer to your question, it depends on the strength of the backbone, but it's unlikely in a properly designed one while still being more likely than in a decent spaceframe/monocoque. In the one you show the body is going to have to be a decent monocoque to avoid it.
[Edited on 29/11/09 by iank]
Anonymous
posted on 29/11/09 at 09:08 PM Reply With Quote
Nearly all backbone chassis are really only part of the structure the body stiffens them a lot.
The only backbone chassis I can think of that didn't transfer any chassis loads the body was the Triumph Herald.
blakep82
posted on 30/11/09 at 01:09 AM Reply With Quote
here's aproper backbone chassis
that other one looks like it'll twist all over the place. i wouldn't go near it
________________________
t.j.
posted on 30/11/09 at 07:01 AM Reply With Quote
The upper ball-joint mounting - wishbone looks tiny to me!
posted on 30/11/09 at 12:16 PM Reply With Quote
Stupendously under-engineered, much like the chassis IMO. I can't believe that is a finished design?
Perhaps the designer is planning for any slight wheel loadings to simply tear off the wheel before the entire chassis folds in half like a book?
Benonymous
posted on 1/12/09 at 09:50 AM Reply With Quote
The front and rear sub-frames are going to be able to apply a huge amount of torsion to that wimpy "backbone". As it stands, I wouldn't even call that a chassis either. If the body is substantial and rigidly bolted to the sub-frames it might be OK but here in Australia the finished chassis would be subjected to a torsion test and the metalwork we see here would fail that miserably. I like the Lotus Europa backbone, even though they rusted like bastards!
Daddylonglegs
posted on 1/12/09 at 10:03 AM Reply With Quote
No way would I even consider getting in that!
I reckon a few miles around where I live and the potholes would destroy it in minutes!
New Topic New Reply
