cd.thomson
posted on 30/11/09 at 01:11 PM |
c20xe thermostat sensor threads
Flak monkey is kindly helping me out with my water temperature sensor and fitting it into the block where the old sensor is in the thermostat.
Now there are two threaded holes here so I'm thinking of screwing in a hosetail so I can bleed from the block as well as the top hose
(I've realised I wont be able to bleed the air from the top hose until the thermostat opens - a big nono for a first start procedure!)
does anyone know the threads on these? I thought M10, as the threads for the oilways are M15 but just want to check??
I can't find any M10 hose tails, so I was wondering if threads on the waterways are imperial fittings as standard??
could really do with getting this "easy" job sorted so thanks in advance.
Craig
stevepj
posted on 1/12/09 at 09:11 PM |
not sure on the sizes, the smaller hole for the engine temp sender is a taper thread, is it 1/4 npt?
Re bleeding the top hose, I think I have a spare thermostat housing with an allen bolt bleed screw on the rad side of the stat, if I can find it and
you send me ur address you can have it.
