Author: Subject: Brake problems on mates car still !!!!
Kitlooney1000
posted on 13/4/04 at 08:09 PM Reply With Quote
My mate 7 has had a problem with the breaks from before he bought it. On a journey the front brakes would seize on. we swoppped the pipes on the Mk3 capri master to see if the master was at fault, but it was still the fronts that were seizing. replaced the front flexi's and the rear one anyway. replaced the front calipers with recon ones, the rear cylinders with new ones, the rear drums, the front pads, the pedals were stripped out and a new set fabricated to fit the car. there is enough play on the pedal to allow the piston on the master to come fully out. the pipe work in the engine bay runs either side of the engine for the front brakes, as in it comes out of the master, t-piece to split the pipe, then one pipe for each side around the engine to the new flexi's. the only thing we havent done is replace the brake lines, although they have been flushed several times.
One thought is the heat from the 4-1 exhaust manifold on the 1700 xflow is expanding the brake fluid, as it is fine if you release the pressure through the calipers bleed nipples.
Any thoughts anyone, before the car has a sledge hammer taken to it, or turned into a dutton, either way is easy
[Edited on 13/4/04 by Kitlooney1000]
Andy S
posted on 13/4/04 at 08:28 PM Reply With Quote
Interesting problem - does the brake pedal / push rod assembly allow the master cylinder to return to the fully open position i.e. is there any play?
If there is then it sounds like a new M/C or a rebuild is needed.
Ooops just red the thread fully - and you say it does return - Makes no sense.
Whats the layout - is the master higher or lower than the calipers?
Andrew
[Edited on 13/4/04 by Andy S]
Mark Allanson
Sounds like rear adjusters again.
You press on the brakes, the rear shoes extend, the adjusters should then hold them just off the drum, if they are worn, the springs slowly return, squeeze the rear slaves and push the fluid back into the system. The only place for it to go is in the front calipers, and binding the front brakes
Harking back to my Fiat days (everyone yawns!!), the 60's-80's FWD fiats had a clutch type adjuster with single leading shoes. the rear shoe would not adjust oner time as the shoes wore, and the front calipers would start binding. the cure was simple, drive the car in reverse at 20mph and slam on the brakes, repeat until you are nearly sick and the problem was sorted. If the owner was told to do one emergency reverse stop every week, the problem never reoccured. Italian engineering and Yorkshire solutions!!
Kitlooney1000
posted on 13/4/04 at 08:31 PM Reply With Quote
Good idea Mark.
The car has been tested with the rear brakes disconnected from the master cylinder with the same effect, still binding the fronts
Andy S
posted on 13/4/04 at 08:39 PM Reply With Quote
The way the Capri M/C works should prevent any pressure from the rear going to the front as the circuits are separate - In effect its two separated cylinders.
Any pressure should be released back into the resevoir as a valve is opened when the piston fully returns. - I would replace the M/C - does the fluid easiliy return into resevoir when the pistons are pushed back into the calipers?
Andrew
Mark Allanson
posted on 13/4/04 at 08:42 PM Reply With Quote
Whe you disconnected the rears brake pipes, did you replace the unions with bleed nipples and bleed out the master cylinder? If not, trapped air would give the same result as worn rear adjusters!!
I just love brake problems, they really make you think!!
Kitlooney1000
posted on 13/4/04 at 08:47 PM Reply With Quote
Andy, havent tried to push the pistons back in, will try that next. Will also try to shield the brake pipe above the exhaust to see if that helps.
Mark Allanson
posted on 13/4/04 at 08:56 PM Reply With Quote
I am not sure about tha capri MC, but most separated MC's have a floating piston between the rear and front chambers so pressure from the rear will push the floating piston against the front chamber increasing the pressure to the fronts. The pressure will also push the pedal back. Have you got a solid or rubber pedal stop (see where I'm going now!)
Kitlooney1000
posted on 13/4/04 at 09:03 PM Reply With Quote
there is still play in the pedal, the m/c piston is fully out, even disconnecting the pedal doesnt help. but to answer your question the pedal stop is solid.
Mark Allanson
posted on 13/4/04 at 09:18 PM Reply With Quote
That has ruled out most things. There are only 2 reasons why the brakes bind - pressure build up or mechanical resistance (in the pistons). As you have changed the front calipers, it has to be either rear adjusters, master cylinder or boiling fluid too close to the exhaust, air in the system that will not bleed out normally - like you, I am starting to run out of ideas.
NS Dev
posted on 14/4/04 at 06:41 AM Reply With Quote
In my experience it is nearly always the pistons seizing that causes the brakes to stick on. Just worth checking that the re-con calipersare not seized, I have had this once, funnily enough with cortina calipers, supposedly recon but must have been sat on a shelf for ages and one were seized when I put it on!! Another new one cured the problem!!
posted on 14/4/04 at 07:43 AM Reply With Quote
Very easy to diagnose the master cylinder piston is not returning enough to vent fluid back to the master cylinder.
On cars with servo this is usually caused by someone twiddling with the adjuster on the pushrod stub that comes out the cylinder end of servo in an misguided effort to reduce pedal travel.
With non-servoed brakes you should always use a master cylinder designed for non servo use with a circlip and pushrod retaining washer at the end.
[Edited on 14/4/04 by britishtrident]
Kitlooney1000
posted on 17/4/04 at 07:15 PM Reply With Quote
Have now ruled out the overheating, moved the brake pipes so they ran in a cool area, the bottom of the engine bay. stripped down the master cylinder and fitted new seals all roung even though its a new one any way, no good. enquired as to the price of a new cylinder and my mate is now ordering a set of tandems from rallydesign. hopefully that will solve the problem
posted on 18/4/04 at 06:07 AM Reply With Quote
All he needs to do is make sure the mastercylinder pushrod come back far enough to allow the piston to return fully.
Kitlooney1000
posted on 18/4/04 at 09:42 AM Reply With Quote
have ruled that out already, the recuperating valve in the master is fine, opens and closes with the movement of the piston. the fluid even returns to the reservoir when you push back the brake shoe. nothing else left to check now
Baldrick
posted on 19/4/04 at 11:50 AM Reply With Quote
This happened on mine. Problem was cured by fitting positive return spring on pedal. Just the friction of the pedal/pushrod etc. was enough to keep the brakes hard on once applied.
Kitlooney1000
posted on 19/4/04 at 03:22 PM Reply With Quote
Thats the next plan.
