Author: Subject: GSXR throttle body trumpets
dlatch
posted on 6/12/09 at 12:14 PM Reply With Quote
anyone know where to find these cheap? ideally i would like the rubber ones, does anyone know if they can be removed from the original airbox?
cheers
duncan
Jos Fury
posted on 6/12/09 at 12:24 PM Reply With Quote
Maybe I can help you with these :
GSXR. Upper set 70mm, two other sets 60mm long
53mm mounting dia.
Prefer to sell all together. 50 pounds incl. shipping from NL ?
Jos
posted on 6/12/09 at 12:39 PM Reply With Quote
Thats a pretty good price...
It's Evolution Baby!
dlatch
posted on 6/12/09 at 03:40 PM Reply With Quote
hi jos
won't need all of them but may be interested in a set of same length i will need to have a measure up and see how much room i have to play with first.
if you want to split let me know
cheers
duncan
[Edited on 6/12/09 by dlatch]
scutter
posted on 6/12/09 at 07:25 PM Reply With Quote
Just for info, yes they can be pulled from the airbox, I can't remember which engine sizes are which but one comes with 2 long and 2 short in the same airbox.
They are good for holding one the air filter backplate.
ATB Dan.
chasmon
posted on 6/12/09 at 08:46 PM Reply With Quote
I'd like two of the ones in the back row if anyone wants to buy and split... I have 4 of the slotted ones and two of the shorter ones too that I can swap if need be.
53mm mounting dia.
Jos
chasmon
posted on 6/12/09 at 08:48 PM Reply With Quote
FYI Slotted ones are from GSXR1000 and the unslotted ones are from a GSXR750 but only the centre two HTH
dlatch
posted on 6/12/09 at 11:40 PM Reply With Quote
Dan
what ones u have fitted there? they look perfect, also wanted them to hold on the filter back plate plus improve airflow
Jenko
posted on 7/12/09 at 10:44 AM Reply With Quote
I used the gsxr600 ones (on gsxr600 tbs's ) ;-)
I ended up buying two air boxes from ebay to get them as they normally end up not on the tb's....But, they have proved very good.
Click
[Edited on 7/12/09 by Jenko]
scutter
posted on 7/12/09 at 01:04 PM Reply With Quote
They are 750 one's (I think )
The front 2 barrels do stick out of the bonnet.
ATB Dan.
Jos Fury
posted on 8/12/09 at 11:43 AM Reply With Quote
I prefer not to split up due to keeping the shipping costs as low as possible.
Jos Fury
posted on 16/12/09 at 05:15 PM Reply With Quote
Still up for sale
