NigeEss
posted on 6/12/09 at 12:56 PM |
Corsa C headbolt info wanted
Hi all,
Anyone know the headbolt sequence and torque setting for the Vauxhall Z12XE 1.2 Corsa C ?
Please don't say if the daft angle torque thing
I'm assuming it's start in the middle and work clockwise outwards.
austin man
posted on 6/12/09 at 01:58 PM |
Bet you have to torque then turn through 45% i'm sure that's what we had to do on the last Corsa we did a head on. The angle thing isnt a
problem just make a circular cardboard disk and split into segment then align with a fixed point
posted on 6/12/09 at 02:07 PM |
quote: Originally posted by NigeEss
Hi all,
All stretch bolts require an angular torque AFAIK, since you torque past the yield point of the bolt. The correct figures usually come with the new
stretch bolts IME, and may have the sequence as well.
If you can't find the exact sequence then just start in the middle and work diagonally outwards on both sides.
boggle
posted on 6/12/09 at 02:09 PM |
i have them on my auto data handbook but i cant work out how to paste the screen shot up.....
stage one 25nm
stage 2,3and 4, 60 degrees...
posted on 6/12/09 at 02:11 PM |
It's the daft angle torque thing, sorry Have a look on Cavweb or corsa forum. I did my daughter's earlier this year but she took her
book and I cant remember it offhand. The sequence is not what you said there it's middle then ends then all the bits in between. There are about
4 different stages to the tightening procedure. First stage was only about about 20lb ft, then 90*, 90*, 90* then 30* but that's just an
example not the actual figures
boggle
posted on 6/12/09 at 02:15 PM |
boggle
posted on 6/12/09 at 02:19 PM |
NigeEss
posted on 6/12/09 at 02:34 PM |
Thanks all,
double thanks Boggle
boggle
posted on 6/12/09 at 02:42 PM |
some other torque settings you may find usefull.....
