Author: Subject: DOHC + Type 9 Box
Dan.
posted on 12/12/09 at 03:52 PM Reply With Quote
DOHC + Type 9 Box
Had a quick search but cant find anything, as far as I know all dohc sierras came attached to a mt75 box, my question is will a dohc bolt up to a type 9? as i have a type 9 sat in my garage and have been offered a 2.0 dohc for nothing
Hping its a yes as it will get me one step closer to IVA and then being able to swap for a propper engine
[Edited on 12/12/09 by Dan.]
Mr G
posted on 12/12/09 at 03:58 PM Reply With Quote
Yes, dohc pressure plate with type 9 friction plate.
Dan.
posted on 12/12/09 at 03:59 PM Reply With Quote
perfect thanking you
Mr G
posted on 12/12/09 at 04:08 PM Reply With Quote
Ah just remembered the dohc and its meaty flywheel which can cause problems - Usual route is to take some meat off of it.
I'll look for the relevant info as my memory is not what it was
austin man
posted on 12/12/09 at 04:14 PM Reply With Quote
the double OHC is a bit heavey and lacks tuning potential, its worth considering what you want out of the car before fitting this type ogf motor. If its more power in time then I would go for a Pinto as a minimum or a zetec
Dan.
posted on 12/12/09 at 04:24 PM Reply With Quote
not really bothered about performance, this is only a stop gap to get the car on the road whilst I save and precure the bits for the engine i plan to put in the car later
Mr G
posted on 12/12/09 at 04:25 PM Reply With Quote
Here's some info
Linky 1
And here is the thread where scotty G said his mate took 10mm off his flywheel
Linky 2
(In a modified dutton thats why i remembered it )
G
Dan.
posted on 12/12/09 at 04:40 PM Reply With Quote
Originally posted by Mr G
Here's some info
Linky 1
Linky 2
G
Very helpfull thankyou!
johnston
posted on 12/12/09 at 05:52 PM Reply With Quote
I have a DOHC sitting that was going to go into my mk1 escort, when I was reading up on it I read a cvh flywheel will fit and be lighter etc etc.
Not sure which one but or if indeed was true as I ended up going down a different route.
snapper
posted on 13/12/09 at 09:17 AM Reply With Quote
If you fit the DOHC now, fitting a Zetec later will be a doddle, inlet and exhaust on the same side.
I eat to survive
I drink to forget
Dan.
posted on 13/12/09 at 03:25 PM Reply With Quote
dont plan to go the zetec route that would be far too sensible lol.
Thanks anyway though!
Vindi_andy
posted on 14/12/09 at 09:54 AM Reply With Quote
Got a spare MT75 box if you want it going very cheap. OBviously will bolt straight on.
Have gone DOHC and MT75 myself as it came with the donor. If you want to come and have a look at a 4 seater and and DOHC install and pick my brains and get an MT75 gbox into the bargain send me a u2u and we can exchange no.s
Dan.
posted on 14/12/09 at 12:22 PM Reply With Quote
The engine turned out to have no ancillaries, so I purchased myself a pinto 205 block off ebay last night., it comes with all ancillaries etc keeps things nice and simple, and was pretty resonable at £80 I think?
[Edited on 14/12/09 by Dan.]
