phil_far
posted on 14/12/09 at 05:56 PM |
Leaking Brake Master Cylnder
I do not know if thsi is the right place to post this topic but I have my twin master cylnder (Girling) fitting that is leaking. Thsi is the oil
feed form the reservior. I changed the fitting 3 times already (longer, shorter and now with a copper washer) but after a week i find a film of oil
(very small) around the fitting. The master cylnder are teh 0.677 and 0.7 (if I am not mistaken) found in the standard floor mounted twin bias bar set
up. The pipes are braided swaged ends
Can someone help out
Philip
antonio
posted on 14/12/09 at 08:05 PM |
not a great help from me, but check if you do have the right tread..hydrolock should help if you only have a small gape.
check reservoirs, plastic one are craps and leak may comes from it.
cheers
