Author: Subject: 1.8 silvertop
AndyLockwood
posted on 15/12/09 at 11:20 AM Reply With Quote
1.8 silvertop
i have the posibility of purchasing a 96 silvertop with ecu but no keys im not concerned about having to cat the car i just want advise on the ease of getting round the no keys issue
cliftyhanger
posted on 15/12/09 at 11:30 AM Reply With Quote
will be using the ecu? or are you going aftermarket (carbs, efi or whatever) as the key is linked to the ECU, not the actual engine. If that makes sense.
If you intend using the std EFI, then yes, it is important. Buy elsewhere, they are cheap enough and plentiful. Or even another ECU with keys, there must be loads on the bay.
AndyLockwood
posted on 15/12/09 at 11:34 AM Reply With Quote
1.8 silvertop
the engine is in really good condition and a good price which is why im tempted. I was going to just use the standard efi unit for sva purposes then alter after if i fancy. So i can just purchase a new ecu with keys?
AndyLockwood
1.8 silvertop
will121
posted on 15/12/09 at 12:37 PM Reply With Quote
some good info here from Big_wasa on previous thread ECU sure it will have the ford PATS imobiliser where you need the matching keys, if you havent got it, ebay come up with matching sets but can be around £40-£50.
big_wasa
posted on 15/12/09 at 05:47 PM Reply With Quote
It will not run with out the rdif chip found in the key.
Ecu and keys sell on ebay for around £25 if your patiant.
How do you know its a good motor if it doesnt run ?
AndyLockwood
posted on 15/12/09 at 07:19 PM Reply With Quote
i drove the donor about two months ago very smooth engine. unfortunately keys got lost
big_wasa
posted on 15/12/09 at 07:31 PM Reply With Quote
great so just need to find another ecu and key.
I paid £25 for the last one, it came with a full lock set.
One before that I got for a quid.
you could have a look in your locall scrapie, the one I use, its rare to find the keys.
You can get the ecu reprogramed for a new key but thats mega bucks unless you have a mate that works for ford.
96 will be eec-v thats the 104 pin version so there is lots of wiring. The eec-v also has obd2 diagnostics so you can see whats going on with a scanner.
[Edited on 15/12/09 by big_wasa]
AndyLockwood
posted on 16/12/09 at 05:10 PM Reply With Quote
PICKED UP THE ENGINE TODAY
CAME WITH ECUEscort/Orion 1.8 litre 16 Valve
93-94
Ford EECIV
92FB12A650BE
7225397
XEF2FBBE
130BHP
MONK
ENGINE COST ME NOTHING IN THE END JUST TRYING TO FIND ID NUMBERS TO WORK OUT AGE?
big_wasa
posted on 16/12/09 at 06:02 PM Reply With Quote
130 spec you jammy bugger. I want an inlet manifold from one of them.
AndyLockwood
posted on 16/12/09 at 06:25 PM Reply With Quote
hehe im chuffed to bits
AndyLockwood
posted on 16/12/09 at 06:36 PM Reply With Quote
its a 60 pin ecu and i have the loom. what security was fitted to this ecu. the guy said the key he had before he lost it had no chip
big_wasa
posted on 16/12/09 at 06:41 PM Reply With Quote
could you give me some lotto numbers as that one is pre pats and no chip.
The alarm on the pre pats cars just switched earths.
[Edited on 16/12/09 by big_wasa]
big_wasa
posted on 16/12/09 at 06:47 PM Reply With Quote
some pin outs for you.
Escort
1 Battery
2
3 Speed Sensor
4 Ignition Control Module
5
6
7 ECT Sensor
8 Fuel Pump Relay
9 MAF
10
11 Emission Canister Purge (37)
12
13
14 Pulsed Secondary Air Injection (37)
15
16 Ignition Control Current Return
17 Data Link
18 Engine Diagnostic Connector
19 Engine Diagnostic Connector
20 Current Return
21 Idle Control Valve
22 Fuel Pump Relay
23
24 Camshaft Position
25 IAT Sensor
26 TPS
27
28 PAS
29
30
31
32
33
34
35 Injector 4
36 Ignition Control Module
37 Engine Control Relay
38
39 Injector 3
40 Current return
41
42 Octane Coding Plug
43
44 HEGO
45
46 Sensor Common
47 TPS
48 Data Link
49
50 MAF
51
52
53
54
55
56 Ignition Control Module
57 Engine Control Relay
58 Injector 1
59 Injector 2
60 Current Return
AndyLockwood
yes yes yes
big_wasa
posted on 16/12/09 at 06:54 PM Reply With Quote
It must have been an old stock car when reged as thats a 93-94 ecu and you say the car was on a 96.
big_wasa
posted on 16/12/09 at 06:58 PM Reply With Quote
pic 2
big_wasa
posted on 16/12/09 at 07:03 PM Reply With Quote
I tend to bin the egr system to keep the system as bassic as pos along with the speed sensor input and a few other bits.
Pin numbers on this diagram wont match the pin out I listed above.
big_wasa
posted on 16/12/09 at 07:08 PM Reply With Quote
This diagram gives you an idea on how to connect the engine controle relay aswell as the fuel pump.
AndyLockwood
posted on 16/12/09 at 10:27 PM Reply With Quote
Thanks alot for the info
