Author: Subject: Self-Tappers and IVA
Rosco
posted on 18/12/09 at 11:58 AM Reply With Quote
I attached the brake pipes to the chassis using plastic P-clips and self tappers, but now questioning whether Mr IVA is going to take issue with this.
They feel very secure to me but now is the time to change them, before I put the body on.
If I need to change them, then what to? The plastic brake pipe clips don't look very strong to me. What about small rivets and P clip?
marcjagman
posted on 18/12/09 at 12:03 PM Reply With Quote
Personally I think rivets, not that there's any thing wrong with self tapers but they may take the opinion that they could vibrate out.
wicket
posted on 18/12/09 at 12:10 PM Reply With Quote
Used self tappers with thread lock, no problem at SVA and all appear to be secure last time I looked.
James
posted on 18/12/09 at 12:43 PM Reply With Quote
Rosco,
Keep you eyes on the Clubs and Events section for your local Guildford meet up at Newlands Corner!
James
ReMan
posted on 18/12/09 at 01:18 PM Reply With Quote
Should,nt be a problem, bearing in mind production vehicles are held together with self tappers
speedyxjs
posted on 18/12/09 at 05:37 PM Reply With Quote
I brought some plastic clips on ebay for the brake pipes (they were suggested by others on here). I just brilled the right size hole and pushed them in. They are nice and tight even after some bending of the pipes.
marcjagman
posted on 18/12/09 at 08:33 PM Reply With Quote
Push in clips? Never seen them, seams like a good idea to me. Where did you get them from?
iank
posted on 18/12/09 at 10:08 PM Reply With Quote
Rally Design amongst other places.
http://www.rallydesign.co.uk/product_info.php?products_id=9971
Anonymous
The Black Flash
posted on 18/12/09 at 11:31 PM Reply With Quote
Dax use the push-in ones too. They seem to be a pretty standard thing.
Angel Acevedo
posted on 19/12/09 at 01:56 PM Reply With Quote
I would think they´re OK,
Not sure about the pus-in clips as they may let moisture into the tubes, no big problem if used on panes though.
