Author: Subject: Inline thermostat
Paul (Notts)
posted on 21/12/09 at 08:16 PM Reply With Quote
Inline thermostat
Looking for an inline thermostat as apposed to one that fits into the inlet manifold for my Rover V8..Any suggestions…
Paul
Rod Ends
posted on 21/12/09 at 08:30 PM Reply With Quote
A quick google:
C&R Racing inline coolant thermostat / thermostat housing.
Paul (Notts)
posted on 21/12/09 at 08:36 PM Reply With Quote
Where can I get one???
not doing well on Google tonight...
Paul
Rod Ends
posted on 21/12/09 at 08:42 PM Reply With Quote
www.crracing.com/custom-built-products/thermo-check-valves
posted on 21/12/09 at 08:54 PM Reply With Quote
Car builders solutions do one.
posted on 21/12/09 at 08:58 PM Reply With Quote
Some bikes have them, notably a 90's model CBR1000
Myke 2463
posted on 21/12/09 at 09:20 PM Reply With Quote
Some SD1's + 2000's had an inline stat QH or QTH234 Raw used to sell about £32.
MERRY XMAS
r1_pete
posted on 21/12/09 at 09:30 PM Reply With Quote
Doesn't one of the Land Rover Discoveries have an inline stat?
stevec
posted on 21/12/09 at 10:39 PM Reply With Quote
I have one that was off a Rover kV6 with a bypass built in.
Andybarbet
posted on 21/12/09 at 10:48 PM Reply With Quote
Freelander has one too on the 1.8 k series
, plenty of those on ebay being broken up.
posted on 21/12/09 at 10:49 PM Reply With Quote
The TF, ZT and later Freelanders (and possibly othe Rovers) use an inline thermostat that is sensitive to pressure as well as temperature (PRT).
posted on 21/12/09 at 11:03 PM Reply With Quote
The Freelander 1.8 PRT thermostat ( it should actually be called a PRRT but nobody calls it that ) is the same one used on the Defender TD5 Part number PEL100990 or sometimes PEM100990 it goes into the bottom hose and requires a equal Tee piece fitted in the top hose.
The Range Rover P38 4.0 & 4.6 V8 used a different design
Land Rover part number: PEM101130
Both can be found on ebay for less than £20.00
posted on 21/12/09 at 11:05 PM Reply With Quote
In its original home KV6 ones are a bit fragile the thermostat outer casing develops cracks and then leaks.
posted on 21/12/09 at 11:08 PM Reply With Quote
Originally posted by Rod Ends
A quick google:
Looks like an expensive custom made way to cook an engine --- it has no warn coolant flow around the thermostat when the stat is close, so the thermostat won't open until the engine is well on the way to an over heat situation.
sebastiaan
posted on 22/12/09 at 06:58 AM Reply With Quote
Or, there could be an internal bypass (i.e. a small pilot hole drilled in the stat...) to ensure proper warm up of the thermostat. Just because there is no bypass hose doesn't mean there is no bypass.....
posted on 22/12/09 at 07:57 AM Reply With Quote
Thats a bodge to get out of trouble rather than a desirable way to do it.
Paul (Notts)
posted on 22/12/09 at 09:43 AM Reply With Quote
Thanks for all the replys...
now sorted with a discovery series 2 one for £13 new from paddock spares..
