Author: Subject: Zetec crank pulley
norfolkluego
posted on 28/12/09 at 11:38 AM Reply With Quote
Zetec crank pulley
What's the best way of getting the crank pully bolt out to fit my trigger wheel, how do I stop the engine turning, would putting it in gear do
blakep82
posted on 28/12/09 at 12:35 PM Reply With Quote
in gear (1st maybe though it shouldn't really matter) and with handbrake on, that engine won't be turning at all
________________________
Mal
posted on 28/12/09 at 01:00 PM Reply With Quote
If the above does not work, remove the starter motor, put a G-clamp onto the flywheel and let it wedge against the bell housing.
Werner Van Loock
posted on 28/12/09 at 03:07 PM Reply With Quote
why put a trigger wheel on a zetec? It has a standard trigger wheel on the flywheel. Unless you fitted a CVH one.
http://www.clubstylus.be
norfolkluego
posted on 28/12/09 at 03:47 PM Reply With Quote
Good guess Werner, I did fit a CVH one to save weight, hence the need for the trigger wheel
madteg
posted on 28/12/09 at 05:43 PM Reply With Quote
Jam tee bar against chassis and flick the key and bingo its done, make shaw you have it on the right side.
austin man
posted on 28/12/09 at 05:46 PM Reply With Quote
the later comment is best used as a last resort though. It is a very effective method though. I used this method and copious amounts of heat to remove the crank pulley on my Austin
posted on 28/12/09 at 06:38 PM Reply With Quote
Decent air wrench !
Micael
posted on 28/12/09 at 07:20 PM Reply With Quote
i agree with Rusty. A good air impact wrench does it.
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
