rgrs
posted on 29/12/09 at 01:05 PM |
so what is it then ?
linky
iank
posted on 29/12/09 at 01:13 PM |
R reg is 77 so it's very likely to be an age related donor plate and maybe the DVLA screwed up the V5 paperwork - not unknown for pre SVA builds
where things were even more confused than now.
It says Locust (which is a plywood and ladderframe chassis 7 lookalike). So I suspect one of those has given up it's identity to a MK build.
I call ringer.
[Edited on 29/12/09 by iank]
Anonymous
jacko
posted on 29/12/09 at 01:14 PM |
I have never seen the car it says from hull but i think its some one off here
Jacko
graememk
posted on 29/12/09 at 01:26 PM |
i would say its a indy, but with the log book of a locust.
jacko
posted on 29/12/09 at 01:29 PM |
Mk use to make the locost do you think he has put [ locust ] and not locost by mistake
Hammerhead
posted on 29/12/09 at 01:38 PM |
i like that he has put that there is so much he can say about the car, then says nothing at all about it
iank
posted on 29/12/09 at 01:45 PM |
But he says it's an Indy. Looks a newly minted car to me.
On another note who builds a car and then drives it 65miles in 3 years?
Anonymous
TimC
posted on 29/12/09 at 01:48 PM |
Hmmm.
Engine's an unusual choice - may well have come out of a Locust.
We've seen it all before - BEC MK crashed and reborn with an S2000 motor anyone?
TC
MakeEverything
posted on 29/12/09 at 02:03 PM |
Dont forget, you can call it whatever you like when you SVA.....
But, i think its a ringer, but id still probably buy it if i had the cash.
Kindest Regards,
Richard.
Danozeman
posted on 29/12/09 at 03:10 PM |
When was fiat twin cam first madfe? age related using the engine??
If not then its a ringo star,
Dan
mookaloid
posted on 29/12/09 at 03:53 PM |
Clearly a ringer. Obviously an Indy chassis etc from the description but registered as a Locust
One car with the identity of another is a ringer - how can it be anything else?
People continuing to do this sh*t will only give us genuine builders a bad name and make it more difficult for us to put our cars on the road in the
future
snakebelly
posted on 29/12/09 at 05:51 PM |
i reckon its the other way round, i think its a J&C Locust on a dead MK's papers. Ladder frame chassis with 3/4" marine ply body
skinned with ALi, built one myself in the 80's. I think the hint is the width of the cappings on the body sides
iank
posted on 29/12/09 at 05:55 PM |
V5 is for a 77 locust so it's on locust papers.
Looks more like an Indy than the locusts I've seen
e.g.
Anonymous
prawnabie
posted on 29/12/09 at 05:59 PM |
Its worth mentioning that alot of locusts were re-chassied into book frames before SVA came in. My car was originally a Locust and was re-chassied in
1995.
posted on 29/12/09 at 09:08 PM |
id suggest ringer.
BUT, you are allowed to replace all parts if necessary, i just dont think you can use a different chassis from the wrong manufacturer.
Now he could argue that it was originally a locust, then previously rebuilt before sva onto a spaceframe, than more recently rebuilt onto an MK indy
chassis. This would not be far outside the law, maybe even legal.
However, id never pay £6750 for it even if it was legal!
iank
posted on 29/12/09 at 10:40 PM |
quote: Originally posted by JoelP
id suggest ringer.
I concur
quote: BUT, you are allowed to replace all parts if necessary, i just dont think you can use a different chassis from the wrong manufacturer.
correct
quote: Now he could argue that it was originally a locust, then previously rebuilt before sva onto a spaceframe,
at which point after the MOT he should have got the V5 updated i.e. he'd used the old locust as a donor the same as any kit build in those days.
It's outside the grace period for fixing those kinds of problems so you'd need proof of when it was done and that it had been on the road
MOT'ed to get that fixed. Hard when the cars look externally similar.
than more recently rebuilt onto an MK indy chassis. This would not be far outside the law, maybe even legal.
No, the new spaceframe would have to be exactly the same in every detail - i.e. off the same manufacturers jig or at least built to identical
measurements. There's no grey area on that in the DVLA rules.
quote: DVLA rebuilt vehicle rules
The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the
same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt).
Well no, at best you'd have to be worried about it being taken away and crushed as a ringer every MOT.
I'd be working out how much it was worth and subtracting the cost of putting it through IVA+hassle if I were considering it. Probably a round
£1000 if you consider everything.
Anonymous
Lightning
posted on 31/12/09 at 10:22 PM |
Not a Locust all the wrong shape. I should know as I made one.
