Author: Subject: Sierra Indicator Cancelling Spacer
mccsp
posted on 17/1/10 at 04:16 PM Reply With Quote
I somehow managed to loose the Sierra Indicator Cancelling Spacer from my adjustable steering column. Does anyone have a spare one that I could beg/steel or buy?
Picture of a borrowed (but must return) one below:
Sierra_Indicator_Cancelling_Sp
They have the following markings: "G 35190 81A613318AB FORD"
They are apparently no longer available from Ford.
Why do it the easy way, when I can do things my way!
Angel Acevedo
posted on 17/1/10 at 08:05 PM Reply With Quote
PVC Fabrication
What material is it?
Plastic?
Couldnt you fabricate out of PVC pipe/Connectors??
smart51
posted on 17/1/10 at 08:10 PM Reply With Quote
Damn, how unlucky are you? Only today I've agreed to give one away, see here. I got this one from a ford dealer about 4 years ago. It was cheap, from memory. Worth a try.
posted on 17/1/10 at 08:18 PM Reply With Quote
I just blobbed some MIG weld on the shaft and filled it into a roughly correct shape. Does the job nicely.
mccsp
posted on 17/1/10 at 08:28 PM Reply With Quote
Think I need to become a contibutor, ten I could have seen the free one from smart51.
I thought it might be what I needed, but didn't think I would get the new status processed quickly enough
