Author: Subject: powder coated sump
Nitrogeno25
posted on 26/1/10 at 10:35 PM Reply With Quote
powder coated sump
I sent my sump for powder coating and the guy at the shop told me they apply paint outside and inside the sump. At first I don't like the idea of painting inside the sump, but then I see lot of cars have their sumps painted inside and outside, also some gearboxes...
What do you think?
blakep82
posted on 26/1/10 at 10:42 PM Reply With Quote
i would have thought the powder coat would get inside too.
my diff cover is powder coated in and out, so i wouldn't worry too much
________________________
big_wasa
Dont do it.
They can mask the inside. It takes time and that costs a bit extra, but better imho.
mookaloid
doesn't sound right - but I can't think of a good reason why
austin man
posted on 26/1/10 at 11:02 PM Reply With Quote
wouldnt like to think that paint was coming loose in the sump, particles equal filter blockage abrasion etc.
I would only have the outer done if anything. I would rather paint it, having seen what powder coating is like when it get the slightest damage
mcerd1
posted on 26/1/10 at 11:05 PM Reply With Quote
I got mine done and he blasted it then masked the inside before coating - all without me even having to ask
I've got his number if anyone up in this part of the world needs stuff done....
[Edited on 26/1/10 by mcerd1]
blakep82
posted on 26/1/10 at 11:12 PM Reply With Quote
ah, blocked oil galleys, jets and stuff, noooo, they're right, don't do it!
Bluemoon
posted on 27/1/10 at 10:07 AM Reply With Quote
Powder coat might not be petrol/oil proof.. Silly thing is our Fiesta has the inside of the rocker cover painted (as ford intended).. Took the rocker off at about 50K to find the paint peeling inside! Not good no damage seems to be done though.. So I scraped off the paint from the inside (it's not going to rust in there with all that oil after all)..
Dan
perksy
posted on 27/1/10 at 06:18 PM Reply With Quote
Used to work at a company with Powdercoating facilities and there's no need for them to coat the inside of the sump
DON'T Let them do this, there is a danger that it will peel off in bits, especially if the surface hasn't been prepared properly
Heard a story of an XE that went bang because the cam cover had been coated on the Inside and it had started to peel off blocking the oilway's
davidwag
posted on 27/1/10 at 06:25 PM Reply With Quote
A couple of months ago i had an old TVR in to complete a wiring loom and get the vehicle running properly, after the owner had rebuild the engine and restored the chassis. After about a week of starting first time in the morning it suddenly had no oil pressure. After dipping the oil it appeared grey and horrid, so i decided i should drain it and change it. I undid the sump plug and nothing happened. Poking inside the drain hole it apeared there was something blocking the hole, after clearing it a grey sludge came out.
At this point i knew the sump would have to come down so i could inspect it, this revealed that the owner had had the sump powder coated inside and out. Not only had the powder coat come away from the inside and blocked the pick-up, but the sump had not been properly cleaned after it was blasted. The blasting powder had been left behind all the bafles and had traveled up through the oil system destoying the oil pump and bearings. The engine had to be stripped, cleaned and re-assembled with new bearings, pump etc.
Nitrogeno25
posted on 28/1/10 at 05:23 PM Reply With Quote
First thanks for your replies.
I agree 100% with you.
I only ask because I find out and lots of cars have the sump painted inside from the factory. I checked 4 different sumps from different car makers which are painted inside!!
mcerd1
posted on 28/1/10 at 05:29 PM Reply With Quote
my new tin sump for the focus was/is painted on the inside
I've no idea what paint they use, but its definatly not powdercoat......
[Edited on 28/1/10 by mcerd1]
Bluemoon
posted on 30/1/10 at 10:28 AM Reply With Quote
True and it may go the same way as my rocker cover one day!
