Author: Subject: Beading aluminium tube
flak monkey
posted on 27/1/10 at 07:05 PM Reply With Quote
Does anyone here have the facilities to bead 1.6mm wall aluminium tube?
I will need various lengths of pipe made up for the intercooler plumbing for my car. Most will be short lengths.
Thanks,
Sera
http://www.motosera.com
robinj66
posted on 27/1/10 at 07:18 PM Reply With Quote
Not exactly local to you but Car Builder Solutions have made up pipes for me in the past .
Alan B
posted on 27/1/10 at 07:23 PM Reply With Quote
Yep....got a beading tool....but sadly even less local.....
ashg
cbs can do it £3 per bead depends if you need loads doing
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Hammerhead
posted on 27/1/10 at 07:31 PM Reply With Quote
is that nipple beading tool still at b&q? i keep looking out for it but never seen one.
I want to bead my pipes after those lads got burnt recently.
mangogrooveworkshop
posted on 27/1/10 at 08:09 PM Reply With Quote
Yep its still available
Want me to pop in and get the code for you.
Blake I send you mine to do your pipes with if you post it back.
Howlor
posted on 27/1/10 at 08:18 PM Reply With Quote
We made one up quite easily. Lathe up your male and female rollers, ideally mount them on a roller bearing but not really necessary. Then we found drilling and tapping the vice jaws the easiest way and mount the rollers on the side of a vice.
Put your tube over the male roller then wind the vice steadily while turning your tube round. Once the die has bottomed you should be left with a nice bead.
Simples.
ashg
posted on 27/1/10 at 08:38 PM Reply With Quote
I was one of those lads. Thats why i now know cbs charge £3 a bead lol
carpmart
posted on 28/1/10 at 10:09 AM Reply With Quote
I followed the advice on here before and use one of the plumbing beading tools from B&Q, it works a treat at putting a 'lip' on the ally pipes for the rubber hoses to bite into.
Very locost at £10ish!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Hammerhead
posted on 28/1/10 at 10:43 AM Reply With Quote
That would be great if you are passing, i've tried a medium sized store and a super huge buggar and still no joy.
Ash, hope you are healing well.
Steve.
johnH20
posted on 30/1/10 at 09:40 PM Reply With Quote
I would be interested to know where this B&Q tool can be found. Tried my local ( Chelmsford ) with part number and it did it seem to exist on their computer any more.
gazza285
posted on 30/1/10 at 11:49 PM Reply With Quote
You have a lathe, make your own and offer it as a kit car service.
wilkingj
posted on 31/1/10 at 12:20 PM Reply With Quote
Got mine from the Big store in Peterborough lat year.
I picked mine up on the way back from Newark show, thus it cost me nothing in petrol costs.
B&Q do those Pliers, at £13. (Metal Oyster Kit B&Q part no 0000003344668 )
Dont know if this helps... they dont show up on their webiste, and never were easy to find.
Best Regards
Geoff
http://www.v8viento.co.uk
mangogrooveworkshop
posted on 31/1/10 at 10:58 PM Reply With Quote
I would go down to the block and quade but some one has broken the car
I will check what part of the plumbin dep they are in other wise I will buy some and pass them on
mangogrooveworkshop
posted on 31/1/10 at 11:01 PM Reply With Quote
http://www.ibpconex.co.uk/viewProduct.php?id=364
40inches
posted on 4/2/10 at 02:19 PM Reply With Quote
I found them on the plumbing pipe fittings section (not in the tools section) low down the display, prepacked with 2 15mm pipe fittings. Took me around 1/2 hr to find them, assistants had not got a clue what I wanted
hicost blade
posted on 4/2/10 at 06:26 PM Reply With Quote
Pro Comp can bead pipes as from today, U2U Matt.....
Brommers
posted on 4/2/10 at 09:12 PM Reply With Quote
If you know someone with an AC TIG welder (like me ) then just put a bead of weld around the end of the pipe. Simpler than pressing a bead into the tube wall and just as effective...
iank
posted on 4/2/10 at 09:14 PM Reply With Quote
Yep that's where they are in my local B&Q (a warehouse store).
Anonymous
flak monkey
posted on 5/2/10 at 09:16 PM Reply With Quote
Got one of those oyster beading tool whatsits from B&Q today, seems to do the job. Creates a bead of lots of little dots around the tube. Will certainly stop hoses blowing off.
£15 from B&Q, found in the plumbing section
Sera
