Author: Subject: Tools for sale
tom windmill
posted on 28/1/10 at 11:08 PM Reply With Quote
Tools for sale
Hi a while since ive posted on here but have a few bits that might be of interest to a few of you so here goes:
SIP 25034 Trade Weldmate T140W Brand new never used - £300 ono
Gas/Gasless (230v). Gas/Gasless mode
What ive taken from the box:
Gas Mode - Provides slag free welding on mild steel, aluminium and stainless steel with the appropriate gas & wire
Gasless Mode - Utilises Flux cored wire, excellent for outside use even in windy conditions
Versatile 25-130 amp power - Welds from 0.7mm to 6.0mm mild steel
Heavy duty transformer - 107 Amps @ 20% duty
Extra low current performance - Delivers 25amp minimum power
Automatic wire speed control with manual override - You select the power setting and the wire speed sets
Turbo fan cooled.
Thermal overload.
Wheel mounted
Ready to us accessories included.
130 amps of welding power - Will weld up to 6mm mild steel
Mig operation - Provides slag-free welds on mild steel, aluminium and stainless steel when used with appropriate gas and wire
Top loading - For smoother wire feed
Reliable wire feed mechanism - To prevent wasted downtime
Turbo fan cooled - Forced air cooling, created by a turbo fan directed over the internal coils, ensures welding at higher powers for longer periods
Versatile - Welds from 0.7 - 6 mm mild steel, even through rusty or coated surfaces
Automatic wire speed with manual over-ride - Quick setup with manual over-ride to ensure precision. You select the power setting and the wire feed sets automatically
6 power settings
Professional torch – With the new steel liner which gives a smoother feed, trigger controlled power and gas prevents undesired arcing and gas wastage
Extra low current performance - Able to deliver a unique 25 amps minimum power for welding very thin materials easily
Variable wire spool size capability - Accepts both 0.7kg and 5.0kg spool sizes to offer both portability and economy
Heavy duty case and chassis - Added durability and reliability
Large bottle facility - For maximum economy
Thermal overload - Maximum protection guaranteed
Fully mobile - Wheel mounted for convenience
230V 13 amp - Use from any domestic supply
1 year manufacturers warranty - For peace of mind
Specifications
• Input voltage : 230V
• Fuse rating : 13 amps
• Current range : 25 - 130 amps
• 6 Power settings
• Duty cycle @ 20% : 107 amps
• Approx weld thickness : 0.7mm - 6mm
• Net weight : 32 kgs
• Dims : 620 x 460 x 900mm
SIP Air Hammer Kit brand new - £25
190mm air hammer, kit contains 5 heat treated chisels :
175mm panel cutter
175mm spot weld breaker
175mm flat chisel
175mm tapered punch
175mm sheet metal trimmer
SIP Engine cleaning gun brand new - £10
multi purpous cleaning gun with 750cc stainless container
SIP Air speed saw brand new - £25
SIP Air Nibbler brand new - £25
SIP Recirculating spot sandblasting gun brand new - £25
If you want any more info. let me know,
Ill have to see what it costs to post it all but if anyone wants anything ill go find out or you can collect from East Yorkshire
Cheers Tom
Front Row Joe
posted on 28/1/10 at 11:14 PM Reply With Quote
u2u re engine cleaning gun
tom windmill
posted on 28/1/10 at 11:21 PM Reply With Quote
replied
alexg1965
posted on 29/1/10 at 07:03 AM Reply With Quote
u2u re. nibbler sent
jonrotheray
posted on 29/1/10 at 07:15 PM Reply With Quote
2nd dibs on nibbler please
pgtips
posted on 29/1/10 at 10:04 PM Reply With Quote
u2u ref SIP Recirculating spot sandblasting gun brand new.
If I die, my biggest fear is that my wife sells all my toys for the price I told her I bought them for...
cosmick
posted on 31/1/10 at 09:21 PM Reply With Quote
I am interested in the air saw if it is still for sale please.
