Author: Subject: Xflow on bike carbs
Sij
posted on 31/1/10 at 12:49 PM Reply With Quote
Xflow on bike carbs
I have a 1600 Xflow fitted with bike carbs and it isnt running properly. It back fires thru the carbs also spits flames out of the carbs. It seems to idle fine and performance seems fine.
Also when I switch the ignition off it stays on and tries to restart it self for about 3 seconds. Could these problems be related to timing or do the carbs need to be set up?
Can I cause damage to the engine driving it like this?
RichardK
posted on 31/1/10 at 12:58 PM Reply With Quote
Sounds like timings too retarded causing the engine to run too hot, and yes you can damage your engine running like this.
When the ignition timing is TOO ADVANCED,the engine may suffer from spark knock or ping. Whenignition timing is TOO RETARDED, the engine willhave poor fuel economy and power and will be very sluggish during acceleration. If extremely retarded,combustion flames blowing out of the open exhaust valve can overheat the engine and cause the engine to run on.
Rich
[Edited on 31/1/10 by RichardK]
Gallery updated 11/01/2011
mookaloid
posted on 31/1/10 at 01:52 PM Reply With Quote
As above Richard knows what he is talking about
davew823
posted on 31/1/10 at 03:23 PM Reply With Quote
X-flow with bike carbs
You did not indicate the RPM when back firing occurred, but it sound like you are at a min of two jets sizes to lean. Fatten up the fuel mixture.
Dave
will121
posted on 31/1/10 at 06:44 PM Reply With Quote
is the running on thing after turning the ignition off a general xfow thing as think i remember when i pulled out my 1300xfow had a wire connection to the carb as a anti-dieseling thingy which would now be lost with bike carbs
Sij
posted on 31/1/10 at 08:26 PM Reply With Quote
Thank you for the advice guy's
How do I set the timing?
