<<  1    2  >>
Author: Subject: Need to drill a square hole?
pewe
posted on 4/2/10 at 11:21 AM Reply With Quote
Hadn't seen this before and I know it defies all logic but it's possible........
Cheers, Pewe
PS Blake V V probably have to be used in a milling machine or similar as the side forces must be considerable.
http://www.ohgizmo.com/2009/10/07/square-holes-drilled-with-a-watts-drill-blows-my-mind/
[Edited on 4/2/10 by pewe]
liam.mccaffrey
posted on 4/2/10 at 11:25 AM Reply With Quote
wankel rotary engine anyone? cool though
Build Blog
Build Photo Album
NigeEss
posted on 4/2/10 at 11:26 AM Reply With Quote
Very clever, kinda reminds me of a Wankel engine though !
Dammit..too slow
[Edited on 4/2/10 by NigeEss]
Irony
posted on 4/2/10 at 11:27 AM Reply With Quote
Interesting, I don't think I'll be putting one in cordless drill however.
That animation reminds me of a wankle engine.
Slow twice over on the wankle engine comment. Now I feel a right wankle.
[Edited on 4/2/10 by Irony]
deezee
posted on 4/2/10 at 11:31 AM Reply With Quote
WITCHCRAFT...... BURN THE WITCH
FFTS
posted on 4/2/10 at 11:47 AM Reply With Quote
Is it just me or does this remind anyone else of a wankel engine?
Chris.
blakep82
posted on 4/2/10 at 11:56 AM Reply With Quote
it reminds me of something... i can't think what though
er, i guess it won't work in just any drill though?
________________________
adithorp
posted on 4/2/10 at 12:02 PM Reply With Quote
I can't open the link at the moment but does it work like a Wankel engine?
adrian
http://jpsc.org.uk/forum/
posted on 4/2/10 at 12:10 PM Reply With Quote
As the article says - it's not a new concept. In fact, if you drill a hole with a conventional 2-flute drill bit the resulting hole will be slightly triangular. If you want a truly round hole you need to finish off with a reamer, which has many cutting edges and (usually) irregular spacing between them to reduce oscillations.
It must be slightly scary to watch that drill work, as it has to rattle around a fair bit to do its job - bit like a Wankel rotor in fact!
posted on 4/2/10 at 12:13 PM Reply With Quote
Hey... that works just like one of those funny Mazda engines. What do you call them again...
It's Evolution Baby!
tegwin
posted on 4/2/10 at 12:16 PM Reply With Quote
Presumably its more designed for milling applications rather than for bob to use with his hand drill :p
www.verticalhorizonsmedia.tv
Richard Quinn
posted on 4/2/10 at 12:21 PM Reply With Quote
... and doesn't that take all the fun out of trying to fit a square peg into a round hole?
blakep82
posted on 4/2/10 at 12:23 PM Reply With Quote
ah, the mazda B series engine!
designer
posted on 4/2/10 at 12:29 PM Reply With Quote
I bet the bits are expensive with all the side loads.
I once had to buy a lathe which 'turned' round bar into flat sided profile.
The bar went the normal way and the cutters, one cutter per surface, went the other! Swarf and coolant flew everywhere, all very complicated!
mangogrooveworkshop
posted on 4/2/10 at 12:41 PM Reply With Quote
fantastic
mcerd1
posted on 4/2/10 at 01:10 PM Reply With Quote
I bet you'll find some of your donor bits have holes like that in them
...so how do they do hexagonal ones then ??
[Edited on 4/2/10 by mcerd1]
blakep82
posted on 4/2/10 at 01:34 PM Reply With Quote
would have thought they're more likely to be water/laser cut can't think of where these holes would be right enough
bodger
posted on 4/2/10 at 02:15 PM Reply With Quote
Wankel Wankel Wankel! aaahh that's better
Confused but excited.
posted on 4/2/10 at 02:19 PM Reply With Quote
Only if it hasn't been sharpened/ground correctly.
mcerd1
posted on 4/2/10 at 03:15 PM Reply With Quote
what about up the up the middle of a pinto's dizzy shaft ?
I think cap head bolts are forged (allan key ones) but anything else like them.....
blakep82
posted on 4/2/10 at 04:03 PM Reply With Quote
never looked at a pinto dizzy, but i see what you mean about cap head bolts. i always just assumed they were cast or something. or milled
Alan B
posted on 4/2/10 at 04:14 PM Reply With Quote
Non-round holes are either forged (Socket capscrews etc.) or broached (keyways, splines etc.) or if thin enough just punched out.
BTW, I think the word you are all thinking of is Wankel
bimbleuk
posted on 4/2/10 at 04:22 PM Reply With Quote
Yep great engine for providing a stead supply of RWD chassis with very low milage. Yes I have an RX7 sat on my drive with blown apex seals. I bought it like that though, the wankel engine will get sold for parts.
boggle
posted on 4/2/10 at 10:50 PM Reply With Quote
think ill stick with my waterjet......but i like the spirograph pattern in the middle.......
u2u me for details
gazza285
posted on 6/2/10 at 10:06 PM Reply With Quote
I usually bray in my square section taper drift until the approximate size is reached, do the other side to even out the taper a bit, then grind off the overspill. Its a bit rough mind, but works for the 'smithies.
<<  1    2  >>
