Author: Subject: WHAT MASTER CYLINDER IS THIS???
tilly819
posted on 5/2/10 at 09:00 PM Reply With Quote
hi all
could someone tell me that master cylinder this is
i belive it to be ford sierra?
certainly says ford on the cap but when ever i serch round for a replacement (this one leaks) i cannot find anything that looks like it.
any help would be great since the brake system is driving me up the wall iv just replaced the two rear wheel cylinders after one blew out last night Rescued attachment master cylinder.jpg
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
doddy
posted on 5/2/10 at 09:03 PM Reply With Quote
it looks differant to mine and mine is a sierra one
[Edited on 5/2/10 by doddy]
mookaloid
posted on 5/2/10 at 09:13 PM Reply With Quote
I think there were several different styles but they all have 2 outlets at the front and 1 in the middle.
whitestu
posted on 5/2/10 at 09:15 PM Reply With Quote
That looks the same as my sierra one.
Stu
stev24276
posted on 5/2/10 at 09:20 PM Reply With Quote
it looks like a early sierra and escort one
bodger
posted on 5/2/10 at 09:22 PM Reply With Quote
It's the same as my Sierra one. I got mine new off ebay but it was a couple of years ago.
[Edited on 5/2/10 by bodger]
mistergrumpy
posted on 5/2/10 at 09:24 PM Reply With Quote
Sierra. Definitely as I've the same in my garage. There were around 3 different types made for Sierra's. If you do a search you'll find the different types as I'm sure I saw it on this site. Possibly a British Trident post as he's well up on MC's
tilly819
posted on 5/2/10 at 09:36 PM Reply With Quote
ok great at leat i can be sure where it came from now.
so the next problem is were do i get a new one from in a short space of time????
thanks again
tilly819
posted on 5/2/10 at 09:38 PM Reply With Quote
thanks again
mistergrumpy
posted on 5/2/10 at 09:45 PM Reply With Quote
Is yours knackered or was it just the wheel cylinders knackered?
Anyhow have you tried Ebay or Bigg Red sells repair kits.
If not try brakes international here
tilly819
posted on 5/2/10 at 10:19 PM Reply With Quote
wheel cylinders were nackered,\ replaced them and still keep getting ail threw after litres of brake fluid.... no visible leaks apart from a small amount of seepage of seepage on the MC were the plunger push rod goes in.
tilly
whitestu
posted on 6/2/10 at 09:35 AM Reply With Quote
If it's any help in identifying the right one at the factors, mine came off a 1990 1.8CVH engined Sierra Sapphire. Brake setup was drum rear end, non ABS.
Stu
posted on 6/2/10 at 01:03 PM Reply With Quote
There are at least 6 different types of Sierra brake master cylinders. 3 Girling and 3 Bendix.
The type you have is identical to ours and going on previous experience you're going to really struggle to get a repair kit for it. It's also the most expensive of the Sierra master cylinders to buy new. Best price I could find was from Brakes International We weren't in a rush and managed to get hold of a second hand one from here.
Phil
Bluemoon
posted on 6/2/10 at 09:00 PM Reply With Quote
I think you will find it difficult to get and exact replacement as well. Might be worth searching on here for a cheap replacement from a different car (more recent model).. I could only find a new old stock sierra master cylinder on ebay (bendix one). You could get one with a smaller piston (some say the brakes are better for this), I think the "22" on the casting means a 22mm master cylinder.
Dan
MangoFury
posted on 16/3/10 at 03:46 PM Reply With Quote
Originally posted by tilly819
hi all
That's the same as the cylinder on my car. Came from 1.8CVH '89 Sierra - it's a Bendix design. Brakes International list it as BMC4729.
BTW, hello to all on the forum - first posting having joined up to what looks like an interesting forum.
With regard to that brake cylinder, how is anyone attaching it to the brake pedal given that the cylinder has no integral pushrod (having being designed for use with a servo originally)?
locostbuyer83
posted on 14/5/10 at 09:49 AM Reply With Quote
Did you ever find a good source for this cylinder? Mine has also gone and is identical to this one. Dont really want to pay over £100 for a sierra brake cylinder.
