The Knobs
posted on 12/2/10 at 03:25 PM |
ARP bolt lube
Anyone got some spare to fit my rod bolts ?
v8kid
posted on 12/2/10 at 03:29 PM |
Use clear silicone sealant. Tip given to me by a professional engine builder (Wildcat)
posted on 12/2/10 at 03:58 PM |
Be very careful when lubing mission critical bolts especially if they go into a blind hole you can get hydraulic lock.
mcerd1
posted on 12/2/10 at 04:08 PM |
sorry don't have enough left from mine (got enough left for about 2 bolts)
but arp normaly give you 2 torque settings
-one for there lube
-one for normal engine oil (to whatever grade/spec they say)
[Edited on 12/2/10 by mcerd1]
andyharding
posted on 12/2/10 at 06:40 PM |
Engine oil should be fine with the correct torque.
Really don't like the idea of bits of silicone floating round in my oil although I did use it to help the sump gasket seal...
The Knobs
posted on 12/2/10 at 06:54 PM |
Will try and get the oil setting then. The bolts are 3/8" X 1 1/2"ARP 2000 if anyone knows it off the top of their head.
flak monkey
posted on 12/2/10 at 07:09 PM |
The assembly lube is just a good quality moly grease. So if you have some then just use that
Sera
http://www.motosera.com
Angel Acevedo
posted on 12/2/10 at 07:47 PM |
Threadlock
This may be a silly question, but Why not Threadlocker?
You could use the least strong (weakest) if you are concerned with the removal.
Thanks in advance....
norfolkluego
posted on 12/2/10 at 09:46 PM |
70lb ft with moly assembly lube
90 lb ft for 30wt motor oil
Is what it said on the leaflet with my ARP bolts
mcerd1
posted on 15/2/10 at 02:01 PM |
if you need new ARP stuff:
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=ARP100-9902
[Edited on 15/2/10 by mcerd1]
