posted on 17/2/10 at 09:14 PM |
Interesting Doo-Dah's (RS4 Oilways)
As I wanted to remove the AC and PS units from the RS4 engine, I thought that as the engine was 'open' anyway, then I might as well go the
whole hog and take out the drive gears too! Every little (HP) helps!
Proved a little trickier than anticipated... mainly because the RS4 lump has so many tiny oilways and it's a nightmare tracing them back to
source!
Even has them in the gears themselves for their lubrication (see pics)!
Think I've helped the core-plug industry no end post-recession!
Image deleted by owner
[Edited on 17/2/10 by scootz]
It's Evolution Baby!
blakep82
posted on 17/2/10 at 09:25 PM |
ooh thats hot
________________________
tegwin
posted on 17/2/10 at 10:00 PM |
Christ that looks complicated...
I thought the pinto was bad enough
www.verticalhorizonsmedia.tv
Cousin Cleotis
posted on 17/2/10 at 11:16 PM |
cant you just machine the teeth off? i wouldn't want to modify the oil system, looks like a complicated setup.
Paul
blakep82
posted on 17/2/10 at 11:55 PM |
i'd leave them well alone myself.
posted on 18/2/10 at 07:16 AM |
Wimps...
locoboy
posted on 18/2/10 at 07:34 AM |
^^^^^^ PMSL
In for a penny in for a poud eh!
Locoboy
posted on 18/2/10 at 08:11 AM |
Absolutely... !!!
There's no problem as the oilway for each gear was self-contained and core-plugs either side of the pump-shafts holes ensure that flow is
uninterrupted.
I'm waiting for the call from Audi to ask me about this engineering wizardry, but they can f**k right off...
It's mine - ALL MINE! Mwaaaahaaaahaaaaahaaaa
mcerd1
posted on 18/2/10 at 08:47 AM |
Re: tuning an RS4
I think I might have another answer for audi: that car would be so much quicker if it wasn't so lardy - the 'avant' weighs in at
~1850kg (the boss has got one) thats the same as a LWB landrover!
for starters its back seats don't have nearly enough leg room - so they can go
then there must be a good few hundred kilos of sound proofing and trim thats not needed
then there is the electricly adjustable everything - so that can all go
then the AC, sat nav.... etc, so by this stage you'd need an altenator/battery 1/4 the size
and so on, then stick your engine back in - I've suggested this to the boss but he doesn't seem all that keen
[Edited on 18/2/10 by mcerd1]
franky
posted on 18/2/10 at 09:06 AM |
Quick answer to the above problem is buy an RS6, Its a new level of quick.
