Author: Subject: Is my EDIS knackered? Desperate now..... :(
dan8400
posted on 2/3/10 at 11:34 AM Reply With Quote
Can't seem to get an RPM signal from my megajolt. The wiring is all connected up as it should be and have tested this.... twice.
Everything goes where it should but no RPM read out on the dash or on the PC screen. I am connected to the megajolt.... have TPS set up and it's reading on the PC. No igniton changes or RPM changes on PC
Can anyone help.... off to rolling road later. Need this to work
Any suggestions welcome
Dan
[Edited on 2/3/10 by dan8400]
Hey - That's Journey!!!
ashg
posted on 2/3/10 at 11:36 AM Reply With Quote
does the car run?
if it does then it can only be the pip and saw lines between the edis and the mjolt.
i would first check that there are no bad joints in the pip and saw wires with a multi meter. also check if you have them round the wrong way.
once you think it is right and you have an rpm display on the pc, put the idle advance on the mjolt to 5 degrees then trun the mjolt on and off with the engine running leaving the edis 4 on. if the mjolt is controlling the edis 4 then the engine note should change as you turn the mjolt on and off.
another indication that everything is working ok is that the little green box will move around on the table depending on how many revs you give it.
[Edited on 2/3/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dan8400
posted on 2/3/10 at 11:37 AM Reply With Quote
Yes starts and runs. Tested the wires between the EDIS plug and the MJ plug seem ok.
What am i missing? Is there a chance there is a problem inside the MJ?
Dan
ashg
posted on 2/3/10 at 11:44 AM Reply With Quote
could possibly be. have you tried swaping the pip and saw wires round with each other? i thought i had them the right way ad first but they were wrong.
if the engine is running we know the edis4 is ok so its either the pip and saw wires or someting internal in the mjolt.
did you build it yourself?
dan8400
posted on 2/3/10 at 11:46 AM Reply With Quote
Yes tried swapping wires but no change. Tested the wires with the beep setting on multi meter. From MJ plug to EDIS plug. Both beeped.
I built the MJ myself and now am regretting it. Have i buggered it up??
Dan
ashg
posted on 2/3/10 at 11:50 AM Reply With Quote
chances are you have a dry joint somewhere on the mjolt board.
whip it apart and run through the build instructions checking that there are no dry joints or bits of solder between two pins. also check that nothing on the board is touching on the metal case as that will casue you no end of problems.
dan8400
posted on 2/3/10 at 11:52 AM Reply With Quote
Ok i'll whip it off and check it.
Thank you ash
Dan
dan8400
posted on 2/3/10 at 12:04 PM Reply With Quote
Took MJ to bits and tested the voltage points as per assembly instructions. All seem to be ok.
Don't know how else to test it...
Dan
ashg
posted on 2/3/10 at 12:09 PM Reply With Quote
thats strange may be worth posting on the autosport labs forum and see what they have to say. if the voltages are all ok then there must only be a few things that it could be.
http://www.autosportlabs.org/
ashg
posted on 2/3/10 at 12:11 PM Reply With Quote
another little thing i just thought about are you using shielded wire for the pip and saw signals
found this too
The primary test after assembly and voltage checks is to verify communication with a PC.
If you cannot communicate with the unit, check the components and related solder joints around the MAX232A and all of the 0.1uF capacitors around that chip.
Also check the proper installation of the oscillator- check installation orientation and solder joints. Also verify that you see a clock signal going into pin 10 of U1- with a regular DC voltmeter you should see about 2.5V.
Finally, do a general check around the board for bad solder joints, especially all of the pins on U1.
ashg
posted on 2/3/10 at 12:17 PM Reply With Quote
you could try this bout i doubt you will make it before the rr today
http://www.heggs.co.uk/vrssim/
woolly
posted on 2/3/10 at 12:24 PM Reply With Quote
i would try disconnecting the dash rev counter not all are compatible
woolly
dan8400
posted on 2/3/10 at 12:39 PM Reply With Quote
Tried it with and without rev counter
Dan
woolly
posted on 2/3/10 at 01:15 PM Reply With Quote
the thing that caught me out was the the EDIS has 2 earth connections.
feel for you
woolly
dan8400
posted on 2/3/10 at 01:24 PM Reply With Quote
I'm getting jut under 7 volt reading when running the engine on EDIS alone from PIP. 0 volts on the SAW.
Werner Van Loock
posted on 2/3/10 at 07:14 PM Reply With Quote
it is running right, not just cancking? Because the megajolt doesn't give a rev signal during crancking. Only when it's running.
http://www.clubstylus.be
