Author: Subject: guide pins on flywheel
Micael
posted on 10/3/10 at 11:52 AM Reply With Quote
Hi guys,
I have bought a duratec steel flywheel (raceline, secondhand).
This flywheel don't have these small guide pins that steers the clutch plate. It has however small holes for them.
Is it possible to buy thes small pins? or should i make new ones on the lathe?
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
MakeEverything
posted on 10/3/10 at 12:02 PM Reply With Quote
Would roll pins work?
Kindest Regards,
Richard.
posted on 10/3/10 at 12:12 PM Reply With Quote
Called "Dowls" better to salvage them off an old flywheel --- pretty well a standard size accross manufacturers.
mcerd1
posted on 10/3/10 at 12:26 PM Reply With Quote
^^ as above you should be able to find some in any old flywheel - I bet someone on here will have some spare
(I don't think I've got any left though )
or if your really stuck you could get some new ones, bound to be stocked by loads of people
burtons list them linky but I think £1.20 each is a bit steep
[Edited on 10/3/10 by mcerd1]
Mal
posted on 10/3/10 at 12:29 PM Reply With Quote
It is common for the diameter of the dowel holes in the flywheel to be slightly larger than the corresponding holes in the clutch. This arrangement means that the dowels are stepped and it prevents them from coming out during use.
posted on 10/3/10 at 01:23 PM Reply With Quote
^^^^ what the last boy said.
pretty sure I saw these for sale by Burton Power.
Micael
posted on 10/3/10 at 08:04 PM Reply With Quote
Thanks guys.
Now I know where to look.
Micael Moose Åman
