merlin
posted on 20/8/02 at 05:50 PM |
have I found the answer??
Check out the 'magic box' pics in my section of the photo archive and air your views! This fabrication comes complete with all front suspension
brackets and upper shock mounts as well as a steering rack mount. ALL IN ONE BOX! Am I missing something or does this cure all them awful front
suspension setting up problems by simply shortening the rails and welding on this box?? I am looking at marketing this for other locost derived cars
so all feedback will be appreciated....
all the bracket positions are laser cut to a tolerance of +/- 0.2mm and the brackets locate in slots to ensure accuracy. The entire assembly is from
3mm mild steel and can be supplied tack welded or fully welded and with or without wishbones.
shit happens! (but why always to me!!)
stephen_gusterson
posted on 20/8/02 at 06:00 PM |
it looks like a really good idea.
Now if you included wishbones as an option, you have a complete bolt on front end.
atb
steve
Jon Ison
looks good merlin, the only point i would make is, maybe top shock, and even sterring rack mounts could be left out, as in my case i moved both....but
thats just me looking for no bump steer and better (or worse) shocker positioning.......
Btm line.....looks good
merlin
posted on 20/8/02 at 06:05 PM |
available with or without wishbones
working on round cnc bent tube wishbones at the moment, pics should be up next week
Macca
posted on 20/8/02 at 06:31 PM |
As a "soon to start" builder, anything that makes things easier has got to be a good thing.Looks sweet!
Col
andybuff
posted on 20/8/02 at 06:44 PM |
looks Magic can i have one please,how much?
posted on 20/8/02 at 07:18 PM |
Some 25mm square holes in the plate for the chassis rails to go through so far so it can be adjusted if they aren't perfectly cut at the ends would
make fixing it easier, just an opinion.
yours Pete.
theconrodkid
posted on 20/8/02 at 10:11 PM |
Ill take a dozen!
scutter
posted on 20/8/02 at 11:29 PM |
Looks great,
Would have saved me weeks of fannying about, mind you may still need it if car doesn't drive well!
ChrisW
posted on 20/8/02 at 11:44 PM |
I'll take one!! Was going to put my front suspension on tomorrow but I may wait now.
Chris
My gaff my rules
Dunc
posted on 21/8/02 at 08:04 AM |
Maybe some more holes at in the plates to aid airflow through radiator. Looks good though.
philgregson
posted on 21/8/02 at 08:47 AM |
Looks good to me - How much?
merlin
posted on 21/8/02 at 04:34 PM |
The overall dimensions remain as the book, ie - with externally mounted radiator. To keep prices down and bearing in mind that those buying one will
be fabricating their chassis anyway I am supplying it tack welded together for £50 cash, buyer collects. I can however weld it up for you if we can
negotiate a price! The feedback so far has been pretty good and all points have been put into the mark II which will be welded up this evening.
Pictures should be up tomorrow!
bob
posted on 21/9/02 at 07:23 AM |
Merlin
When is the back end in production?
Are you doing a diff carrier for IRS?
bob
posted on 1/1/04 at 12:23 AM |
And
where has the pic gone
posted on 31/3/04 at 09:25 PM |
quote: Originally posted by bob
And
it must've been copyrighted! was wondering where it was myself...
