Author: Subject: Twin Alloy Projector headlamps
russbost
posted on 15/3/10 at 12:43 PM Reply With Quote
Just to let you know I finally have the superb "Photon" twin projector headlamps back in stock
[img] New Twin projectors 1
[/img]
[img] New Twin projectors 2
[/img]
[img] New Twin projectors 3
[/img]
It will probably come as no surprise that these aren't cheap, £230 for a set of 4 - 2 x dip 2 x main. P & P £9.95 a set
I can do 5% off for Locosters.
I know a few of you have been waiting for these & I've emailed/u2u'd all (I believe) apologies if I missed anyone!
turbodisplay
posted on 15/3/10 at 04:24 PM Reply With Quote
They look good! How do you adjust the beam height, is it by the mounts or by an internal adjustment?
Darren
russbost
posted on 15/3/10 at 06:42 PM Reply With Quote
Adjusted by moving the whole lamp on its mounting.
johnH20
posted on 15/3/10 at 07:25 PM Reply With Quote
Hi Russ, please reserve me a set. I will be over to collect this week.
regards
John Hinds
kipper
posted on 15/3/10 at 11:26 PM Reply With Quote
Hi Russ.
Those lights are just what I need for the three wheeler but are they E marked and IVA OK ?
If so reserve me a set.
Regards Denis.
Where did that go?
ChrisW
posted on 16/3/10 at 12:07 AM Reply With Quote
Can you post some dimensions please!
EDIT: and are they all chrome or can you get other colours? (ie black!)
Cheers, Chris
[Edited on 3/16/2010 by ChrisW]
russbost
posted on 16/3/10 at 04:27 PM Reply With Quote
John/Dennis I have reasonable stock of these & they will be repeatable - I'm available this week if you want to collect, away for 5 days next week. By all means give me a ring 07905 879407.
Chris each unit measures 86mm wide by 76mm, they are 130mm from front of lens to rear of lamp. They aren't actually chrome i believe the front part is polished stainless steel - rear section is black, I've had them in grey b4 but thats about it as regards colour choice, but i know you guys know how to drive an aerosol can!!
ChrisW
posted on 16/3/10 at 05:11 PM Reply With Quote
Thanks!
What's the complete overall width of the two of them on the bracket?
Chris
russbost
posted on 16/3/10 at 05:49 PM Reply With Quote
"What's the complete overall width of the two of them on the bracket?"
175mm across the lights, 180mm across the bracket
Denis, sorry missed part of your Q - yes to E marked "E4" & "E9", TTBOMK they are fine for IVA, but (believe it or not!!!) need the very front section of the lens surround covering as it's too sharp! I think Nitram & Cloudy who had some of these off me last year & put them thro' SVA stuck a rubber ring, like an oil seal, to the front of the unit - have a feeling those bits fell off later!
